i took a screen shot at 525 but only captured the memshot. I hope a pic is good enough. :toast2:
THanks Dr. Kim! good times!
yep ,the pic is good enough !!!
congrats man :)
is this wr? THanks :)
Put up the 524 screenies! U rock alvin
i dont have the screeen at 524. just 520. who cares? we have 525!! pic even better! :D
Great Quad core FSB m8 :toast:
W00t? -95.1c with dice, how?
Very nice indeed...
The p5e-vm isn't the tipical overclock (not for benches, very good for small pc's) board but seems to work nicely :D
Very good overclock trans am!!! Those are tough OCing chips.
Have you tried better cooling the NB on the p5e-vm ??? I think it could give you even better scores :)
[ ]s
thanks everyone!
I had a hyper6 rigged so it would go on the NB but the damn thing would get in the way of my container. I had the window open and ran a 45mm fan on the stock HS. This board is the board for ocing 45nm quads. its capable of some amazing overclocks. Dont let the matx and onboard gfx fool you. its a great board! ive tried this cpu with dice on p35 and x38 and the g35 is the best by far. highest on x38 was 490fsb. fyi
WR is actually just 6MHz away (531, held by a P5K). But hey, nice results! I suppose you did do something to the northbridge?
Edit: Yea, I can see some cooling. :) Next, try that with the IGP, and just concentrate on cooling the northbridge (looks like the graphics card is getting in your way. The board is just too tiny for this). I'm sure the IGP can stand really insane clocks.
you would probably replace the gpu with a PCI so its smaller, you might be able to use a slanted tube to get the worth bridge
or just trying to use liquid cooling
@trans_am
what mods did you apply to your p5e-vm?
+1 ???Quote:
none needed ;)
CPU-Z validation?
+1Quote:
+1 ???
Cpu validation? no. I took a picture with my camera instead. I think I've been here long enough that you guys should trust me when I post a cpuz screen. also the temp probe I was using was J type and I had wrong temp probe type displayed so thats why its -95c.
If you want to start a pissing contest, I'll get some ln2 and show you some 530mhz action. I have 2 new retail e7200 to bench this week.
