Post your 45nm Quad OC with full BIOS settings + volts + temps
I have my x3350 up and running. I am to 3.6ghz(450x8) so far, and want to see how my settings, volts, and temps compare to others.
This thread:
-Post full hardware full hardware specs(sig or otherwise)
-Post OCs that you have yet to see fail, and have primed for at least a few hours
-Post Bios Settings
-Post Temps
http://x025.uploaderx.net/x/450x8_3.6ghz_stable.jpg
If image fails, try going here: http://x025.uploaderx.net/x/450x8_3.6ghz_stable.jpg
(For some the embedded image it was not working for me at first, but is now? idk...)
CPU Feature->
Thermal Management Control: Disabled
PPM(EIST) Mode: Disabled
Limit CPUID MaxVal: Disabled
C1E Function: Disabled
Execute Disable Bit: Enabled
Virtualization Technology: Enabled
Core Multi-Processing: Enabled
DRAM Timing-> 5,5,5,12
Voltage Setting->
CPU VID Control: 1.25
CPU VID Spedial Add: Auto
DRAM Voltage Control: 2.12
SB Core/CPU PLL Volage: 1.51
NB Core Voltage: 1.617
CPU VTT Voltage: 1.598
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45
GTL + Buffers Strength: Strong
Host Slew Rate: Weak
GTL Ref Voltage Control: Enabled
CPU GTL 1/2 Ref Volt: 115
CPU GTL 0/3 Ref Volt: 115
North Bridge GTL Ref Volt: 115
Genie BIOS Settings->
Clock VCO divider: Auto
CPU Clock Ratio: 8x
CPU N/2 Ratio: Disabled
CPU Clock: 450mhz
Boot Up Clock: Auto
DRAM Speed: 400/800
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
