BSOD's terrorizing me...
Ok,
I started about this in the DFI 790FX thread but I think it's starting to become an issue enough to give it its own thread.
Most strange thing is that the CPU at least WAS stable on 14x251 in both this board but also in Gigabyte 790FX DQ6 (which is my old board, 4th RAM slot broke and I still should send it for RMA). But now I get BSODs/crashes since past few weeks and they seem to be happening a later when the CPU is clocked lower. I didnt test it at just stock, Ill do that tonight.
Here are my observations:
I get BSOD's when Priming, black screen freeze when playing a game and when browsing the internet and/or WinAmp I get some sort of artifact freeze all across the screen, grey/white vertical lines. All are sorted, not a chaos or so. Sound stutters and then nothing, no response, no reboot or no BSOD (in the crashes, when Priming I do).
RAM is pretty much fine. I used 4 instances of Memtest in Windows each testing 750MB and all covered 550% without errors. That was pretty much ok for me. Also I primed with lower multiplier and same RAM speeds and that was good. I pulled all 4 sticks out and only used one in 3rd slot, BSOD with OC'd CPU. Pulled stick out and got another one in the 4th slot, BSOD. So Im very sure it's not the RAM.
I re-installed Windows XP64 and used latest drivers for GPU, soundcard, mobo and installed all updates for Windows. But it didnt matter, still BSOD.
Two times I got a BSOD and after using the Windows Debugger it blamed the usbehci.sys thing. I disabled USBEHCI controller in BIOS and disconnected all USB devices after that. Also Win32k.sys is getting blamed. I didnt analyze my last 0xD1 DRIVER_IRQ_NOT_LESS_OR_EQUAL BSOD as I got pissed. No driver named there though but I dont know what the Debugger will say.
So yeah, what the hell is going on? Is my CPU simply broken? If so, wouldnt it be more likely it would BSOD at any speed without speeds having an effect? Broken motherboard? I dont think it's the HDD's as I used first only one. When I thought it might be software issue I installed everything new on the 2nd HDD.
Does anyone have a clue or any tips? Thx in advance.
Possible NIC failiure
Sounds like a dying network card or Intergrated network port.
What makes you think that? I mean, when Priming Im not making contact with the internet. At least not by my self then.
This is from my last BSOD:
Microsoft (R) Windows Debugger Version 6.8.0004.0 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [D:\WINDOWS\Minidump\Mini010108-04.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*d:\websymbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
*** WARNING: Unable to verify checksum for ntkrnlmp.exe
Windows Server 2003 Kernel Version 3790 (Service Pack 2) MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 3790.srv03_sp2_gdr.070321-2337
Kernel base = 0xfffff800`01000000 PsLoadedModuleList = 0xfffff800`011d4140
Debug session time: Tue Jan 1 03:16:18.265 2008 (GMT+1)
System Uptime: 0 days 0:24:11.093
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {fffffadb8f31c5d5, 2, 8, fffffadb8f31c5d5}
Unable to load image yk51x64.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for yk51x64.sys
*** ERROR: Module load completed but symbols could not be loaded for yk51x64.sys
*** WARNING: Unable to verify checksum for NDIS.sys
Probably caused by : yk51x64.sys ( yk51x64+48380 )
Followup: MachineOwner
1: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffffadb8f31c5d5, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000008, value 0 = read operation, 1 = write operation
Arg4: fffffadb8f31c5d5, address which referenced memory
Debugging Details:
READ_ADDRESS: fffffadb8f31c5d5
CURRENT_IRQL: 2
FAULTING_IP:
+fffffadb8f31c5d5
fffffadb`8f31c5d5 ?? ???
CUSTOMER_CRASH_COUNT: 4
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffffadf90a47660 -- (.trap 0xfffffadf90a47660)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=fffffadf9bae2008 rcx=fadf8f32d06c0000
rdx=0000000000000000 rsi=0000002800000000 rdi=fffffadf8f31efe6
rip=fffffadb8f31c5d5 rsp=fffffadf90a477f0 rbp=fffffadf90a47ad8
r8=0000000000002800 r9=00000000000001b0 r10=0000000000000014
r11=0000000000000000 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff8000102e5b4 to fffff8000102e890
FAILED_INSTRUCTION_ADDRESS:
+fffffadb8f31c5d5
STACK_TEXT:
fffffadf`90a474d8 fffff800`0102e5b4 : 00000000`0000000a fffffadb`8f31c5d5 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx
fffffadf`90a474e0 fffff800`0102d547 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x74
fffffadf`90a47660 fffffadb`8f31c5d5 : fffffadf`9bae2008 fffffadf`8f325380 00000000`00020105 fffffadf`90a47ad8 : nt!KiPageFault+0x207
fffffadf`90a477f0 fffffadf`9bae2008 : fffffadf`8f325380 00000000`00020105 fffffadf`90a47ad8 fffffadf`00000000 : 0xfffffadb`8f31c5d5
fffffadf`90a477f8 fffffadf`8f325380 : 00000000`00020105 fffffadf`90a47ad8 fffffadf`00000000 fffff800`01036230 : 0xfffffadf`9bae2008
fffffadf`90a47800 00000000`00020105 : fffffadf`90a47ad8 fffffadf`00000000 fffff800`01036230 fffffa00`00000001 : yk51x64+0x48380
fffffadf`90a47808 fffffadf`90a47ad8 : fffffadf`00000000 fffff800`01036230 fffffa00`00000001 fffff6fd`6fc87580 : 0x20105
fffffadf`90a47810 fffffadf`00000000 : fffff800`01036230 fffffa00`00000001 fffff6fd`6fc87580 00000000`00000000 : 0xfffffadf`90a47ad8
fffffadf`90a47818 fffff800`01036230 : fffffa00`00000001 fffff6fd`6fc87580 00000000`00000000 fffff6fd`6fc87501 : 0xfffffadf`00000000
fffffadf`90a47820 fffff800`010258db : 00000000`00000000 00000000`00000000 fffffadf`9066b180 fffffadf`9066b180 : nt!MmUnmapLockedPages+0x154
fffffadf`90a47850 fffff800`010272de : fffffadf`9066b180 00000000`00000002 fffffadf`9c474228 00000000`00000000 : nt!KiDeferredReadyThread+0x5b5
fffffadf`90a47890 fffff800`010273d9 : fffffadf`98af9460 00000000`00000000 00000000`00000000 fffffadf`98af93a0 : nt!KiExitDispatcher+0x4f
fffffadf`90a478c0 fffffadf`75f3ba17 : fffffadf`98af93a0 00000000`00000000 fffffadf`9c474228 fffffadf`98af93a0 : nt!KeSetEvent+0x645
fffffadf`90a47920 fffffadf`8fe4c42d : fffffadf`9bae2008 fffffadf`8f31efe6 00000000`00000274 00000000`00000000 : tcpip!ARPRequestComplete+0x22
fffffadf`90a47950 fffffadf`9bae2008 : 00000000`00000004 fffffadf`9bae2320 00000000`00000000 fffffadf`9bee86ec : NDIS!ndisMSyncQueryInformationComplete+0x24e
fffffadf`90a479b0 00000000`00000004 : fffffadf`9bae2320 00000000`00000000 fffffadf`9bee86ec fffffadf`9bae2008 : 0xfffffadf`9bae2008
fffffadf`90a479b8 fffffadf`9bae2320 : 00000000`00000000 fffffadf`9bee86ec fffffadf`9bae2008 fffffadf`8f3179f2 : 0x4
fffffadf`90a479c0 00000000`00000000 : fffffadf`9bee86ec fffffadf`9bae2008 fffffadf`8f3179f2 fffffadf`9c578850 : 0xfffffadf`9bae2320
fffffadf`90a479c8 fffffadf`9bee86ec : fffffadf`9bae2008 fffffadf`8f3179f2 fffffadf`9c578850 00000000`00000000 : 0x0
fffffadf`90a479d0 fffffadf`9bae2008 : fffffadf`8f3179f2 fffffadf`9c578850 00000000`00000000 fffffadf`8f325380 : 0xfffffadf`9bee86ec
fffffadf`90a479d8 fffffadf`8f3179f2 : fffffadf`9c578850 00000000`00000000 fffffadf`8f325380 00000000`00000000 : 0xfffffadf`9bae2008
fffffadf`90a479e0 fffffadf`9c578850 : 00000000`00000000 fffffadf`8f325380 00000000`00000000 fffffadf`90a5cd08 : yk51x64+0x3a9f2
fffffadf`90a479e8 00000000`00000000 : fffffadf`8f325380 00000000`00000000 fffffadf`90a5cd08 fffffadf`90a47ad8 : 0xfffffadf`9c578850
fffffadf`90a479f0 fffffadf`8f325380 : 00000000`00000000 fffffadf`90a5cd08 fffffadf`90a47ad8 00000000`ffffffff : 0x0
fffffadf`90a479f8 00000000`00000000 : fffffadf`90a5cd08 fffffadf`90a47ad8 00000000`ffffffff fffffadf`00000004 : yk51x64+0x48380
fffffadf`90a47a00 fffffadf`90a5cd08 : fffffadf`90a47ad8 00000000`ffffffff fffffadf`00000004 00000000`00000000 : 0x0
fffffadf`90a47a08 fffffadf`90a47ad8 : 00000000`ffffffff fffffadf`00000004 00000000`00000000 fffffadf`8f317930 : 0xfffffadf`90a5cd08
fffffadf`90a47a10 00000000`ffffffff : fffffadf`00000004 00000000`00000000 fffffadf`8f317930 fffffadf`9bee86f0 : 0xfffffadf`90a47ad8
fffffadf`90a47a18 fffffadf`00000004 : 00000000`00000000 fffffadf`8f317930 fffffadf`9bee86f0 fffffadf`8f2ea804 : 0xffffffff
fffffadf`90a47a20 00000000`00000000 : fffffadf`8f317930 fffffadf`9bee86f0 fffffadf`8f2ea804 00000000`00020105 : 0xfffffadf`00000004
fffffadf`90a47a28 fffffadf`8f317930 : fffffadf`9bee86f0 fffffadf`8f2ea804 00000000`00020105 fffffadf`9bee86ec : 0x0
fffffadf`90a47a30 fffffadf`9bee86f0 : fffffadf`8f2ea804 00000000`00020105 fffffadf`9bee86ec 00000000`00000000 : yk51x64+0x3a930
fffffadf`90a47a38 fffffadf`8f2ea804 : 00000000`00020105 fffffadf`9bee86ec 00000000`00000000 fffffadf`9c578850 : 0xfffffadf`9bee86f0
fffffadf`90a47a40 00000000`00020105 : fffffadf`9bee86ec 00000000`00000000 fffffadf`9c578850 fffffadf`90a47ad8 : yk51x64+0xd804
fffffadf`90a47a48 fffffadf`9bee86ec : 00000000`00000000 fffffadf`9c578850 fffffadf`90a47ad8 fffffadf`ffffffff : 0x20105
fffffadf`90a47a50 00000000`00000000 : fffffadf`9c578850 fffffadf`90a47ad8 fffffadf`ffffffff fffffadf`00000000 : 0xfffffadf`9bee86ec
fffffadf`90a47a58 fffffadf`9c578850 : fffffadf`90a47ad8 fffffadf`ffffffff fffffadf`00000000 fffffadf`90a47a80 : 0x0
fffffadf`90a47a60 fffffadf`90a47ad8 : fffffadf`ffffffff fffffadf`00000000 fffffadf`90a47a80 fffffadf`00000000 : 0xfffffadf`9c578850
fffffadf`90a47a68 fffffadf`ffffffff : fffffadf`00000000 fffffadf`90a47a80 fffffadf`00000000 fffffadf`8f2ea69f : 0xfffffadf`90a47ad8
fffffadf`90a47a70 fffffadf`00000000 : fffffadf`90a47a80 fffffadf`00000000 fffffadf`8f2ea69f 00000000`00000000 : 0xfffffadf`ffffffff
fffffadf`90a47a78 fffffadf`90a47a80 : fffffadf`00000000 fffffadf`8f2ea69f 00000000`00000000 fffffadf`9bae6da8 : 0xfffffadf`00000000
fffffadf`90a47a80 fffffadf`00000000 : fffffadf`8f2ea69f 00000000`00000000 fffffadf`9bae6da8 00000000`00000001 : 0xfffffadf`90a47a80
fffffadf`90a47a88 fffffadf`8f2ea69f : 00000000`00000000 fffffadf`9bae6da8 00000000`00000001 fffffadf`9bee8600 : 0xfffffadf`00000000
fffffadf`90a47a90 00000000`00000000 : fffffadf`9bae6da8 00000000`00000001 fffffadf`9bee8600 fffffadf`9bae2008 : yk51x64+0xd69f
fffffadf`90a47a98 fffffadf`9bae6da8 : 00000000`00000001 fffffadf`9bee8600 fffffadf`9bae2008 00000000`00000001 : 0x0
fffffadf`90a47aa0 00000000`00000001 : fffffadf`9bee8600 fffffadf`9bae2008 00000000`00000001 00000000`00000000 : 0xfffffadf`9bae6da8
fffffadf`90a47aa8 fffffadf`9bee8600 : fffffadf`9bae2008 00000000`00000001 00000000`00000000 fffffadf`8f2e29d9 : 0x1
fffffadf`90a47ab0 fffffadf`9bae2008 : 00000000`00000001 00000000`00000000 fffffadf`8f2e29d9 fffffadf`9bae4f7c : 0xfffffadf`9bee8600
fffffadf`90a47ab8 00000000`00000001 : 00000000`00000000 fffffadf`8f2e29d9 fffffadf`9bae4f7c 00000000`00000004 : 0xfffffadf`9bae2008
fffffadf`90a47ac0 00000000`00000000 : fffffadf`8f2e29d9 fffffadf`9bae4f7c 00000000`00000004 fffffadf`9c2ddab0 : 0x1
fffffadf`90a47ac8 fffffadf`8f2e29d9 : fffffadf`9bae4f7c 00000000`00000004 fffffadf`9c2ddab0 fffffadf`90a5cd08 : 0x0
fffffadf`90a47ad0 fffffadf`9bae4f7c : 00000000`00000004 fffffadf`9c2ddab0 fffffadf`90a5cd08 fffffadf`00000004 : yk51x64+0x59d9
fffffadf`90a47ad8 00000000`00000004 : fffffadf`9c2ddab0 fffffadf`90a5cd08 fffffadf`00000004 fffffadf`9bee86ec : 0xfffffadf`9bae4f7c
fffffadf`90a47ae0 fffffadf`9c2ddab0 : fffffadf`90a5cd08 fffffadf`00000004 fffffadf`9bee86ec fffffadf`9bee86f0 : 0x4
fffffadf`90a47ae8 fffffadf`90a5cd08 : fffffadf`00000004 fffffadf`9bee86ec fffffadf`9bee86f0 fffffadf`8f2e2423 : 0xfffffadf`9c2ddab0
fffffadf`90a47af0 fffffadf`00000004 : fffffadf`9bee86ec fffffadf`9bee86f0 fffffadf`8f2e2423 00000000`00000000 : 0xfffffadf`90a5cd08
fffffadf`90a47af8 fffffadf`9bee86ec : fffffadf`9bee86f0 fffffadf`8f2e2423 00000000`00000000 00000000`00000000 : 0xfffffadf`00000004
fffffadf`90a47b00 fffffadf`9bee86f0 : fffffadf`8f2e2423 00000000`00000000 00000000`00000000 fffffadf`9bee86f0 : 0xfffffadf`9bee86ec
fffffadf`90a47b08 fffffadf`8f2e2423 : 00000000`00000000 00000000`00000000 fffffadf`9bee86f0 fffffadf`9bee86ec : 0xfffffadf`9bee86f0
fffffadf`90a47b10 00000000`00000000 : 00000000`00000000 fffffadf`9bee86f0 fffffadf`9bee86ec 00000000`00000004 : yk51x64+0x5423
fffffadf`90a47b18 00000000`00000000 : fffffadf`9bee86f0 fffffadf`9bee86ec 00000000`00000004 fffffadf`90a5cd08 : 0x0
fffffadf`90a47b20 fffffadf`9bee86f0 : fffffadf`9bee86ec 00000000`00000004 fffffadf`90a5cd08 00000000`00020105 : 0x0
fffffadf`90a47b28 fffffadf`9bee86ec : 00000000`00000004 fffffadf`90a5cd08 00000000`00020105 fffffadf`8f2ea64e : 0xfffffadf`9bee86f0
fffffadf`90a47b30 00000000`00000004 : fffffadf`90a5cd08 00000000`00020105 fffffadf`8f2ea64e fffffadf`9bae2008 : 0xfffffadf`9bee86ec
fffffadf`90a47b38 fffffadf`90a5cd08 : 00000000`00020105 fffffadf`8f2ea64e fffffadf`9bae2008 00000000`00020100 : 0x4
fffffadf`90a47b40 00000000`00020105 : fffffadf`8f2ea64e fffffadf`9bae2008 00000000`00020100 fffffadf`90a5cd00 : 0xfffffadf`90a5cd08
fffffadf`90a47b48 fffffadf`8f2ea64e : fffffadf`9bae2008 00000000`00020100 fffffadf`90a5cd00 fffffadf`9bae2008 : 0x20105
fffffadf`90a47b50 fffffadf`9bae2008 : 00000000`00020100 fffffadf`90a5cd00 fffffadf`9bae2008 01c84c1c`00000004 : yk51x64+0xd64e
fffffadf`90a47b58 00000000`00020100 : fffffadf`90a5cd00 fffffadf`9bae2008 01c84c1c`00000004 fffffadf`9bee86ec : 0xfffffadf`9bae2008
fffffadf`90a47b60 fffffadf`90a5cd00 : fffffadf`9bae2008 01c84c1c`00000004 fffffadf`9bee86ec fffffadf`9bee86f0 : 0x20100
fffffadf`90a47b68 fffffadf`9bae2008 : 01c84c1c`00000004 fffffadf`9bee86ec fffffadf`9bee86f0 fffffadf`90a47bb0 : 0xfffffadf`90a5cd00
fffffadf`90a47b70 01c84c1c`00000004 : fffffadf`9bee86ec fffffadf`9bee86f0 fffffadf`90a47bb0 fffffadf`9bee86b0 : 0xfffffadf`9bae2008
fffffadf`90a47b78 fffffadf`9bee86ec : fffffadf`9bee86f0 fffffadf`90a47bb0 fffffadf`9bee86b0 00000000`00000001 : 0x1c84c1c`00000004
fffffadf`90a47b80 fffffadf`9bee86f0 : fffffadf`90a47bb0 fffffadf`9bee86b0 00000000`00000001 00000000`00000000 : 0xfffffadf`9bee86ec
fffffadf`90a47b88 fffffadf`90a47bb0 : fffffadf`9bee86b0 00000000`00000001 00000000`00000000 fffffadf`8fe4c809 : 0xfffffadf`9bee86f0
STACK_COMMAND: kb
FOLLOWUP_IP:
yk51x64+48380
fffffadf`8f325380 0101 add dword ptr [rcx],eax
SYMBOL_STACK_INDEX: 5
SYMBOL_NAME: yk51x64+48380
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: yk51x64
IMAGE_NAME: yk51x64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4757f90e
FAILURE_BUCKET_ID: X64_0xD1_CODE_AV_BAD_IP_yk51x64+48380
1: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 2
FAULTING_IP:
+fffffadb8f31c5d5
BUGCHECK_STR: 0xD1
+fffffadb8f31c5d5
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
yk51x64+48380
WTF!? It's at least blaming drivers all the :banana::banana::banana::banana:'n time and not my hardware:p:
yk51x64.sys keeps poppin up, i googled that, it came up with a Marvel controler driver conflict...do a google on it.:)
do yourself a favor and disable the onboard ethernet. i had the same problem with the dfi nf4 ultra sli-dr board. i spent over a month going thru support with marvel on the problem, but got nowhere. i gave up and used an intel pro 100 card that i found laying around the house. i'm in the process of evaluating a 790fx board and i think i'm going to stay away from the dfi board. i'll probably get the msi k9a2 plat.
Actually I just noticed I accidentally pressed the analyze button twice.
Anyway, Ill try to disable the Ethernet and see if it works.
Though Ive a little question;
If the Ethernet was really broken, why would a higher clocked CPU cause a sooner crash? And what about the other drivers named in other dumps? It's actually the first time AFAIK I got that driver out of a dump. And how could a Ethernet controller die?
Though I hope it's only that, I mean, that saves a lot of crap and it's no big deal to plug in an Ethernet card.
Well, on the otherhand the only drivers which were named were win32K.sys and usbehci.sys has been named twice. For the rest no other things like Ati or Creative stuff. So it might make sense. Win32K.sys is, I guess, pretty much influenced quickly by other instabilities.
WTF!? Im already running Prime95 for 9 hours and 30 minutes without crapping out. I used 14x249 instead of 14x251. Disabled LAN, USB, Serial and COM stuff in BIOS. But only things it gave me was Prime95 not BSODing but erroring. By dropping HTT 2Mhz it's rock solid again:confused:
So... How the hell is this possible, my CPU has been stable at 14x251 pretty well when I just got it but now it's not? Though I can live with the 30Mhz drop although if this crap happens again Ill send either the mobo or the CPU back for RMA. Ive a spare Gigabyte 790FX DQ6 mobo which has a broken 4th RAM slot. Been lazy so didnt RMA it yet, but Ill do that soon so I'll have a back up mobo if this happens again.
Thx for the help though, any comments about this strange behaviour is welcome though.
