Another KINGBLOCK by Alex_Ta
Looks pretty heavy, what's the mass? Nice plexi holddown.
It looks very nice Hiwa!
Congrats for this Best:)
Cumps
So is there a TEC in there? or what does the thermocontroller do?
400 W(2 X 200w) power on heaters to Counterbalancing the ln2 effects and avoid coldbug on cpu
you are a damn patient one with the polishing.
hiwa have you got any results with this pot on the real cpu already?
Originally Posted by
-cyclone-
Look here:) :up:
http://www.xtremesystems.org/forums/...d.php?t=182523
nachthymnen wow thanks man!
nevertheless, any info from hiwa about how does this pot perform in action? was the heater used during the bench-session?
-cyclone-
look youtube link for first question
yes when u are close the CB just need on thermocontroller and in 1 sec cpu temp will block :up: my QX9650 have cb@ -126 when is @ -124 i on thermocontroller than it's done, temp block @ -124 ;) and i can contimue to bench just need on/off thermocontroller to control temp close of CB :D
hiwa
thats genious!!!!!! innovation rocks!
hiwa
superb! think u should do the automatic adjustable temperature controller, and then it'll be the most innovative pot ever :)
He needs first to test it and after his revision will be final he will do it .
hmmm i think this is the first 1 pot that i have came across that has a thermo controller... very creative, should help alot with cold bugged cpus :D
Solarfall
yeah, me too.
hiwa - very impressive one ;) GJ
isnt plexy broken at below zero?? i was always thinking if i use plexy on a pot, plexy may be broken, which i really dont wanna encounter such a problem like that during bench :D
cold_fire
no man i used it more than 20 times nevere had problem ;)
hiwa
so next one will be plexy mounting.. ;) :D
This really is an ingenious idea! Great way to solve cold boot/cold bug problems, how quickly does it heat up when you actually have LN2 in the pot though? Is it responsive enough to do quick on-the-fly adjustments? Or do you have to somewhat anticipate when you will need it and start it up beforehand?
Maybe you could also apply this idea to evap heads on a cascade (would it be cheaper than those hot gas valves that heat up things??)
Also, how long does it take that huge mass of copper to get cold?
