Mountain Mod Ascension (Custom)
Quick update, MM has released the Ascension model. Here's what they have to say about the Triple Front (Trinity) and the Horizontal rear.
MM
"We are going to produce some of the triple rad front panels – “Trinity” front panels.
And the horizon back panels – the last design..
So you can purchase the Ascension Duality – if you want to get queued up for one.
Just state you want the Trinity front panel, Horizon back panel and desired finish in the comment fields.
Early May looks to be a go on these and some other NEW parts."
So get em while they are hot.
Another Update, Just got these images from MM. These ARE what will be going through production.
http://farm3.static.flickr.com/2316/...f0f851b6_m.jpg
and
http://farm3.static.flickr.com/2341/...cb9376b5_m.jpg
Layout:
http://www.taskforcedagger.net/uploa...sAscension.png
Sketchup: (Thanks go to Marci, and others for their mad skills with Sketchup, I just modified accordingly)
http://www.taskforcedagger.net/uploa...nsionfront.png
http://www.taskforcedagger.net/uploa...ensionrear.png
Now Mountain Mods says that they like the design, but are holding off on any Ascension builds until they can get them on the web site. They even said that they may include my design. I just need a few more people to request Acsension's. :up:
The design has room for 3 pa120.3 rads, either horizontally, or vertically. Other rads will have to be one or the other. The front can be inverted 180 degrees, to have the rads at the bottom.
Thanks for listening, now for some ideas!!!
