High fsb vs tight timings on 875P
Hardware used:
Abit IC7-G
Intel 2.6C @ 3250 Mhz (13*250)
OCZ 3700 Gold
9700 Pro
GAT as follows for both 1:1 and 5:4 tests
Game Accelerator: AUTO
Refresh Cycle Time: Normal
Read Delay: AUTO
Read Delay Adjust: Disabled
Command Per Clock: Disabled
Setting all at AUTO didn’t gain any performance
Programs used:
Scisoft Sandra 2003
SuperPI
3DMark01
PCMark2002
Quake3
250 fsb is 1:1 and 200 fsb 5:4 setting on the memory
Settings Sandra Buffered Int
200 fsb - 2 6 3 3 5435
200 fsb - 2.5 7 4 3 5372
200 fsb - 3 8 4 4 5349
250 fsb - 2.5 7 4 3 5947
250 fsb - 3 8 4 4 5899
Settings Sandra Buffered Float
200 fsb - 2 6 3 3 5419
200 fsb - 2.5 7 4 3 5370
200 fsb - 3 8 4 4 5371
250 fsb - 2.5 7 4 3 6035
250 fsb - 3 8 4 4 5935
Settings Sandra Unbuffered Int
200 fsb - 2 6 3 3 2645
200 fsb - 2.5 7 4 3 2626
200 fsb - 3 8 4 4 2491
250 fsb - 2.5 7 4 3 3285
250 fsb - 3 8 4 4 3097
Settings Sandra Unbuffered Float
200 fsb - 2 6 3 3 2707
200 fsb - 2.5 7 4 3 2634
200 fsb - 3 8 4 4 2482
250 fsb - 2.5 7 4 3 3286
250 fsb - 3 8 4 4 3154
Settings SuperPI 1M
200 fsb - 2 6 3 3 43 s
200 fsb - 2.5 7 4 3 44 s
200 fsb - 3 8 4 4 44 s
250 fsb - 2.5 7 4 3 42 s
250 fsb - 3 8 4 4 42 s
Settings 3DMark01
200 fsb - 2 6 3 3 16593
200 fsb - 2.5 7 4 3 16321
200 fsb - 3 8 4 4 16296
250 fsb - 2.5 7 4 3 16732
250 fsb - 3 8 4 4 16718
Settings PCMARK2002 CPU
200 fsb - 2 6 3 3 8073
200 fsb - 2.5 7 4 3 8053
200 fsb - 3 8 4 4 8047
250 fsb - 2.5 7 4 3 8082
250 fsb - 3 8 4 4 8074
Settings PCMARK2002 MEM
200 fsb - 2 6 3 3 10148
200 fsb - 2.5 7 4 3 10108
200 fsb - 3 8 4 4 9844
250 fsb - 2.5 7 4 3 10800
250 fsb - 3 8 4 4 10712
Settings Quake3 Timedemo
200 fsb - 2 6 3 3 270,4
200 fsb - 2.5 7 4 3 264,3
200 fsb - 3 8 4 4 262,1
250 fsb - 2.5 7 4 3 276,4
250 fsb - 3 8 4 4 274,9
Conclusion
It’s quite obvious that you can use as tight timings as you want and still not be able
to win over high memory bus in overall performance.
So 285 fsb 1:1 at 2.5 7 4 4 for an example will outperform 285 fsb 5:4 at 2 6 3 3,
even 285 fsb 1:1 at 3 8 4 4 will outperform 285 fsb 5:4 at 2 6 3 3.
I can’t say anything about 2 5 2 2 timings since OCZ 3700 Gold doesn’t like them very much, but I doubt they will be so much faster then 2 6 3 3 timings that they will change this conclusion.
So if you plan to run 270-290 fsb use pc4000 memory and run them somewhere between 2.5 7 4 4 and 3 8 4 4 at 1:1, and if you can go above 300 mhz fsb use 5:4 divider with the best timings you can get since the CPU speed that you gained will be worth running 5:4 and loose some memory performance there, overall performance will be better due to the higher cpu clock.
The cpu is the bottleneck when it comes to memory performance so therefore it’s not worth lowering your fsb more then 5-10 mhz or something like that to be able to run 1:1.
Re: High fsb vs tight timings on 875P
Its not too obvious, that same test at 2-2-2 at 5:4 would easily beat 1:1 at 3-4-4 , even at 5:4 2-3-3 I am able to run the same test and its equal or beats 1:1 at 3-4-4. I have the same mobo as you... Its possible your ram doesnt like 2-3-3 very much either, or the the IC7 doesn't like your particular ram at 5:4.
If you ever get your hands on some bh5 chip ram try it again, youll see. :toast:
Re: Re: High fsb vs tight timings on 875P
exactly correct. i proved this myself, even though not through sandra memory bandwidth benchmark. In a real life situation (UT2003)...
I had a-data PC4000 3-4-4-8 running at 1:1 260FSB vs. Mushkin PC3500 running at same FSB with 5:4 2-2-2-5
my sandra scores were a little worse with the mushkin but in gaming performance the mushkin beat out that a-data by a couple of FPS.
~Fizz
Re: Re: Re: High fsb vs tight timings on 875P
2.5-7-4-4 is just as fast as 3-8-4-4.
Going from 2-6-3-3 to 2-5-2-2 gives you quite similar boost than going from 3-8-4-4 to 2-6-3-3. So yes it would have made quite a difference if you had run those tests at 2-5-2-2 instead of 2-6-3-3.
