Another TJ07 build... twin DDC's & twin thermochills
Finally got around to get some photos of my Silverstone TJ07 project that I completed last year. I initally bought a TJ09 and *heavily* modded that, but that proved to be a waste of time, it just wasnt suited for several radiators.
Anyway... specs as follows:
Silverstone TJ07
Thermochill PA120.3 and PA120.2 mounted in bottom of case.
5/8" Tygon Tubing
MCP355 & MCP350 pumps with petras tops.
DTek Fuzion block
Thermochill Res
I also have a single 120mm radiator mounted behind the bottom 5 1/4" bays, and a D-Tek DB-1 pump ready to cool the NB/SB. I just havent gotten around to this yet. You'll see the rad covered with gladwrap just in front of the pumps, and the pump will (eventually) go behind the PA120.3 where the hoses run upward into the top compartment of the case.
I know its not the most efficient system with the 90degree brass bends etc, but with the vortex the pumps are making in the resevoir I dont think flow is a problem :)
I run a B3 QX6700 @ 1.5v and it doesnt go over 60 degrees. However Im considering grabbing an e8400 and see how cool I can get it to 4000Mhz.
Hope you like...
http://i4.photobucket.com/albums/y10...c/DSC00210.jpg
http://i4.photobucket.com/albums/y10...c/DSC00192.jpg
http://i4.photobucket.com/albums/y10...c/DSC00191.jpg
http://i4.photobucket.com/albums/y10...c/DSC00197.jpg
http://i4.photobucket.com/albums/y10...c/DSC00200.jpg
http://i4.photobucket.com/albums/y10...c/DSC00201.jpg
http://i4.photobucket.com/albums/y10...c/DSC00198.jpg
http://i4.photobucket.com/albums/y10...c/DSC00199.jpg
http://i4.photobucket.com/albums/y10...c/DSC00194.jpg
http://i4.photobucket.com/albums/y10...c/DSC00193.jpg
http://i4.photobucket.com/albums/y10...c/DSC00206.jpg
http://i4.photobucket.com/albums/y10...c/DSC00204.jpg
http://i4.photobucket.com/albums/y10...c/DSC00205.jpg
http://i4.photobucket.com/albums/y10...c/DSC00202.jpg
http://i4.photobucket.com/albums/y10...c/DSC00203.jpg
http://i4.photobucket.com/albums/y10...c/DSC00196.jpg
http://i4.photobucket.com/albums/y10...c/DSC00195.jpg
Im kind of bored with this at the moment, so Im considering getting a 780i and clocking an e8400 to 4Mhz for better gaming performance.
Thinking of replacing the Fuzion with an EK Supreme also.
