Flow Testing With Various Blocks
Hey Martin, my apologies for bustin all your good work lately but i'm guessing you will be putting all the data in one place at some point but feel free to delete;)
I did a bit of testing (admittedly not to your level) with various block around this time last year and was told the Storm i used was inferior or my testing was inferior to get such bad flow results but i did buy myself another and got the same numbers.........anything on the Storm??
And again my apologies for agro
Flow Testing With Various Blocks, Barb Sizes and Aftermarket Laing Tops
http://coolercasesuk.co.uk/coolercas...10watt_all.jpg
I hope this might give an indication to expected flow rate with various blocks, hose fittings and aftermarket pump tops.
We've just introduced the small 10-8mm Compression Fittings and Hose to our site so thought it would be a good idea to put some of the most popular blocks head to head in a flow test comparison using the new 10-8mm Fittings as well as the more common 3/8" and 1/2" barbs
For the test i used three new, off the shelf Laing DDC 1T 10watt pumps firstly with an Alphacool Modded Plexi Top then repeated all tests with a Petra's Tech Top. The pumps were ran in for 15 minutes before testing began then each test was replicated three times using all three pumps so an average could be gained from all three pumps.
This in itself was quite interesting as on some tests i was able to see as much as .6LPM deficit between pumps even though they were all ran from the same PSU and same amount of hose lengths used.
The Barbs used were...
10-8mm Compression Fittings with 8mm ID Hose (3ft inlet - 2ft outlet)
3/8" EK Barbs with 3/8" Tygon Hose (3ft inlet - 2ft outlet)
1/2" EK Barbs with 1/2" Tygon Hose (3ft inlet - 2ft outlet)
The blocks used were all that i could lay my hands on at the time without going back to the older generation blocks.
D-Tek FuZion
Danger Den TDX
Swiftech Storm
EK Wave
Alphacool XP Bold
Nothing really surprising with the result to be honest though i was quite surprised at how much the flow was killed with the Storm yet the difference in flow between barb sizes was virtually nothing compared to the less restrictive blocks.
Hopefully i will get the chance in the coming weeks to re-test all blocks with both the 18watt version and the D5 to see how they compare but its pretty time consuming as i'm sure you will appreciate so not sure when that will be.
Anyway on with the results.....
Firstly the Laing DDC 1T 10watt with Modded Alphacool Plexi Top
http://coolercasesuk.co.uk/coolercas...pha_Modded.jpg
........and then the Laing DDC 1T 10watt with Petra's Tech 01 Top
http://coolercasesuk.co.uk/coolercas...watt_Petra.jpg
Laing DDC-1T 18watt with Modded Alphacool Plexi Top
[disclaimer] As stated previously, i don't profess to being any kind of expert in this field or for that matter having the equipment as they might on other forums but these are my findings from a simple exercise that replicates set-ups used by many people on a day to day basis using a stop watch and a 5ltr container. [/disclaimer]
