Best fitting High Perf C.P.U Cooler for AM2
Which one of the top rated CPU Coolers fits the AM2 socket Boards correctly without sloppy play in the mount?
I was going to use my Tuniq 120 for this D.F.I Build but the way it attaches to the retention bracket on the board is very sloppy and it slides around ...not what I would consider even worth while to use! So currently I am using a Zalman 9700 which is OK but would like to step it up to a thermalright 120 XTREME any of you guys running AM2 boards have any input for me?
Nice for Air...Its Amazingly light compared to big hunka metal that my Big Ty was..
Originally Posted by
Brother Esau
I should have specified that I meant Air cooler....sorry:)
It should work just fine....I know they made an updated bracket for the 120extreme....I had just sold mine not to long ago...Worked wonders on my M2N32deluxe before i went under water...:rofl: That sounds funny for some reason...
make shure you lap the base ...Mine was severly bowed new...Nothing a little elbow grease cant fix:up:
