Overclockers` case concept?
Good idea if you are someone that is always messing around with their rig, as is most everyone here.
BTW, I noticed the "long" tubes for the h2o, what pump are ya using and waht temps ya getting...just curious.
I`m using a 600lph pump and i`m having 35celsius on my 3,2@3,7 (1,55V). I dont know how my radeon9500 behaves but it seems not to raise temp even on 1 degree being overvolted at 2,1 volt (1,5default). À 1000lph gave me only temp raise so i got back to my 600lph.
600LPH :slobber:
Thats plenty.
600 liters per hour. Dats a 15bux aquarium pump :) One of the most simple ones.
Dude, BEEP BEEP BEEP News Flash..there is this new thing out called Computer case's.....No only kidding.. Nice man i like it...Totaly away from the norm...its probably one of those things, when people come over, theye say..WHAT THE HELL IS THAT??.. and you smile, chuckle and say "thats my computer dude"... NICE!!!!
wow, i might have to try that, its a pretty good idea.
Nice a lot of places sell these and you can even buy em from furniture shops.
Craig
Nice case but i've a question why the cpu wb has neoprene on it? I don't see any chiller in your loop
nice, how long did it take you to get it all setup
La1kr0diZ, where did you get that holder for your hoses that you have on that stand? Where could i get some of those?
I live in Ukraine. My mom bought several of these for the bathroom to hold the stuff there? and i told her i need one in my workshop. It was fully assembled when she bought it, anyways you can find some of these in the furniture stores like CCW said.
Setting all this stuff up took me some hours, mostly because of these water dividers for watercooler. I made em from old pens, and glued with epoxy.
2 antipop
Coz my bloks get really sweaty when i put an ice like dis in the reservoir: :)
http://laik.modlabs.net/benching/bigice.jpg
I made a new waterblock for my radeon so its not insulated yet.
2 KennethChong
The holders are made from old hoses of larger diameter. I cut them a bit and sticked on a tape. You can use any hooks from tha same furniture shop or make ones urself from some metal paperclips or stuff. More imagination guys :)
Nice push cart test bed man. Thats a great platfrom for testing your ocs.
1 Attachment(s)
Got mine up today, still waiting for my new mobo to come (dripped quite a bit of water on the other one). Im using this to hold my 2 folding rigs, both wc'ed. Im guna put the other system on the 6th shelf it came with.
1 Attachment(s)
1 Attachment(s)
Looks nice! Work around it a bit. BTW, i suggest using cold cathodes to light certain shelves up. 4 example the shelf with the mobo as i did.
Looks, i`m the founder of a new conception :)
Gotta rename the thread :)
Thanks. yea im planning to get a cold cathode for the mobo shelf, its really the only one that i would need any light in, but the power led should help some. I need to get some wheels for it though, its not that easy to move around.
Btw, thanks for the idea! Its guna work great.
Yeh, no mess and a good overclock is a dream. I think i found a solution :)
Rite now i`ve got a new radiator and its size is much bigger than anything fitting that shelf. Dont know what 2 do yet. I`ll show the pix in a while
Im looking for a new rad. Right now i have 2 86 heatercores and its not keeping my nb and 9800 at room temp (dissapointed about that one)
My new rad is from an old 2000W industrial air-condition. Its keeping all of my stuff at room temp even without the cooler :)
made a new ghetto-style wb for my northbridge today and found some pelts in my room mess. Gonna chill dat i865 nb. I want my 310 fsb stable...
I measured the length of yhe copper tube inside the rad - its 10,2 meters! :)
Tommorow im guna go down to a local rad shop and get the biggest one i can find, well to where it will still fit in my tray. Hopefully I wont need any fans.
BTW! you can make one more shelf from a radiator :)
oh, good idea! I might try that.
got mine today, its a used f150 rad he let me have for 20 bucks. God that thing is huge, ill post pics later. Now im sitting here letting it clean itself out :/
