Asus P5N-T Deluxe nForce 780i Motherboard Preview
Nice! but what happened to Dual LAN 780i should have? I hope its stability and reliability are NOT on Striker or P5N32-E levels.
Originally Posted by
xoqolatl
Hey I have absolutely no issues with my P5n32-E... Although I must admit when first getting used to the board it is easy to make not POST. And it was only fine after replacing the useless heatpipe solution.
I think this looks good. Yer what did happen to dual LAN? The cooling looks slightly better to.. although i wish they would get rid of heatpiping altogether.
I had 3 P5N32-Es and it was good board, but there was no good bios for it :( And lots of memory wouldn't work (Patriot LLKs for example); I hope 780i is free of those bugs.
If they released a "workstation" board with this chipset, would it be named P5WN-T? (sounds best if that "-" is removed :D)
is that a heatsink for the pci-e2 controller next to the nb
zanzabar
yup.
AFAIK, 790I has that built into the NB, so should be slightly more elegant.
looks like there is plenty of room between the two blue pci-e slots
Asus should replace the yellow slots for blue or white, I think the majority of people don't need dual LAN which is why its gone
This still doesn't look like it solves the issue of tri-sli and having a soundcard.
I suppose it would be possible with only the GT, since it is single slot. But it does elimate the idea of waterblocks or any dual-slot cooling setups.
hope its out before xmas :)
look nice but does that thing support penryns?
Hmmm...I'd much rather have 790i since it won't have the stupid PCIe 2.0 bridge...
nemrod
Here are some specs;
- Support IntelŽ next generation 45nm Multi-core CPU*
- IntelŽ Quad-core CPU Ready*
- IntelŽ Core™2 Extreme/Core™2 Duo Ready
- NVIDIA nForceŽ 680i SLI™ plus PCIe 2.0 bridge
- NVIDIA Triple-SLI™ Ready
- Dual-channel DDR2 800/667/533
- 1333/1066/800/533MHz
- Stack Cool2 and Heat-pipe Thermal Solution
- 8 Phase Power Design
Not bad, I'll wait for the 790 or Intel's offering though. I think the layout is decent. I still want 8 sata ports, however.
wow, theres literally no option for a sound card in that board, if you choose SLI.
Kunaak
just get this, http://www.newegg.com/Product/Produc...82E16813130080 , it has onboard x-fi
It'll be coming very soon I guess.. Official specs at Asus Global
hstuehmeyer2000
did you just recommend him to buy an MSI??? :doh:
