Just bought two Ati sapphire 3870 and i when i got to run 3dmark it never starts it just hangs up. This is from a fresh install with latest drivers.
any ideas?
any ideas?
Are you on Vista?
i'm on XP Pro and it's happening to me too. it just hangs on the splash screen. i uninstalled and reinstalled 3DMark and i tried with both the beta driver and the new 7.11 driver. i haven't been able to run 3DMark since i got my new cards. i have no idea why.
i'm dllin this now to test the new clocks on my cards, i'm using vista 64bit U so it looks like i'm going to have a few problems....
I got it to work. There is a hot fix for it at futuremark.com
I had that problem before the hotfix came out, when I was on vista32. one of the polling dll's was hanging.. I simply renamed Direcpll.dll and it fixed the hang.
but it looks like they hotfixed it since, like said above.
http://futuremark.com/news/51909_hot...k05_available/
Hotfix for 3DMark06/05/03 and PCMark05 Available!
Thu 2007-10-11 - Posted by Nicklas Renqvist
There's a new unified hotfix available for all the latest benchmarks: 3DMark03, 3DMark05, 3DMark06 and PCMark05. The hotfix updates the following:
* Updated GPU core/memory clock detection library for enhanced compatibility and support for new hardware
* New files are:
o Direcpll.dll (4.10.1.93)
o Entech.sys (5.0.1.1)
o Entech64.sys (5.0.1.1)
This hotfix does not affect any of the benchmark results. A new full install for 3DMark06 Build 1.1.0 (with the hotfix included) will soon be available. Meanwhile, you should download this hotfix and install it now.
i knew it would be something simple like that. thank you guys. that's why i love this site.
