Story from Hardspell
http://www.hardspell.com/english/doc...p?news_id=1362
few other RD790 board .. :up:
http://www.xtremesystems.org/forums/...d.php?t=157385
600 FSB on 1.65 volts with stock cooling? I'll believe it when i see it.
it says 200mhz core htt on the cpuz pick, the fsb its showing is the max that the mb supports
Secound on that, the BIOS says CPU is working at 1800MHz.
The guy has set everething to the max just to take the picture.
600 x 1:2 (AUTO for DDR2-800) FSB : DRAM Ratio = 1200MHz (DDR2-2400)
The 2400MHz "Adjusted DDR Memory Frequency" we see...
OK, the memory frequency isn't calculated that way on AMD64s, but if the memory timings are set by 200, 266, 333, 400 and 533 profiles, it's very practical.
Am I the only one that finds 1.47v max vCore is a little low?
PS. his Phenom is B0 stepping, so more useless benchmarks to come....
I even think he won't publish any tests.Just pics of the board and bios,CPUz and similar.
