Stepping Out With a E6750 + P5K Deluxe
- Intel Core 2 Duo E6750 (G0) - L719A747
- Asus P5K Deluxe 0311 BIOS
- 2x1GB Crucial Ballistix PC2-8500 in black slots
- Water cooled
The following are the basic settings used with all my tests.
Settings Used:
JumperFree Configuration Settings
AI Overclocking: Manual
CPU Ratio Control: Manual
- Ratio CMOS Setting: 8
FSB Frequency: 333
PCI-E Frequency: 100
DRAM Frequency: DDR2-667
DRAM Command Rate: 2T
DRAM Timing Control: Manual
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# Activate to Precharge: 15
TWR: 8
TRFC: 30
TWTR: 8
TRRD: 8
TRTP: 8
DRAM Static Read Control: AUTO
Transaction Booster: AUTO
Boost Level: N/A
Clock Over-Charging Mode: AUTO
CPU Spread Spectrum: Disabled
CPU Voltage: 1.35
CPU Voltage Reference: AUTO
CPU Voltage Damper: Enabled
CPU PLL Voltage: 1.50
DRAM Voltage: 2.20
FSB Termination Voltage: 1.20
North Bridge Voltage: 1.25
North Bridge Voltage Reference: AUTO
South Bridge Voltage: 1.05
Advance CPU Settings
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
PECI: Enabled
USB Configuration
USB Functions: Enabled
Legacy USB Support: Disabled (enable it to detect USB flash drives)
Ambient temperature ~24c to 25c
2671MHz - 333FSB x8 1:1
CPU - Idle
http://img58.imageshack.us/img58/9577/t2idleka8.jpg
CPU - Load
http://img66.imageshack.us/img66/189...d3hoursej7.jpg
Everest Ultimate 4.10.1076 Beta Build - Super Pi 32M
http://img207.imageshack.us/img207/4...superpiki2.jpg
Now that I've confirmed the stock settings work I'll move on.
