Pentosin & PT's UV Dye - Comparitive tests
So I was building a small encloure packed full of UV cathodes and Led's for a friend (It's going to serve as a blacklight/display stand for a bottle filled with UV dye and water). As I wired it all together and sat on my floor, I remembered I was sitting next to a box full of all my new WC supplies.
So, seeing as I was looking for something to do before a 7pm-2am shift at work, I decided to compare the effects and combination of UV dye and Pentosin coolant additive.
The results are as follows:
From Brightest to Weakest:
1. Pentosin G11 + Dye (In Water)
2. Dye (In Water)
3. %100 Pentosin G11
4. Pentoisn G11 (In Water)
So the most common use (G11+Water) is the weakest of the combinations... Not a surprise really.
Anyways, Some pictures for comparison:
Water and UV Dye (Diluted to the proper level):
http://img172.imageshack.us/img172/9371/img0061er6.jpg
%100 Pentosin G11
http://img19.imageshack.us/img19/4025/img0062dn0.jpg
Water and Pentosin G11 (Diluted to the proper level)
http://img505.imageshack.us/img505/4103/img0063wz4.jpg
Blue Pentosin G11 and Petra'sTech Blue UV Dye (Diluted to the proper level):
http://img257.imageshack.us/img257/2847/img0067aj1.jpg
Some last minute fun with a Bawls bottle and UV Dye. :hehe:
http://img170.imageshack.us/img170/9771/img0054kl7.jpg
Dilution levels were determined using a 1 Liter bottle; With 1 part Pentosin G11 to 9 parts water; And one drop of UV Dye per Liter.
