Download
2007/07/11 Update
Download
2007/07/11 Update
Thanks, but nothing improved by me ...
thanks , i will try it ASAP :D.
System feels a bit more responsive, ram latency dropped again, scores slightly better than 1202 at stock speeds (but who runs those :), just SuperPi seems to degrade ... overclocked scores are on par with 1202
changelog :
1301
1. Update CPU uCode to support new processors
2. Enhance memory compatibility under full load (4 DIMM)
3. Revise Q-Fan control code
4. Fix system fail to resume from S3 mode via PS/2 keyboard
5. Update NV RAID ROM to 6.9802.
6. Add microcode not found & update fail message support
7. Finetune CPU fan speed too low warning range
8. Use new French translation
9. Modify General Help string.
10.Fixed floppy item value error.
11.Use new Simplified Chinese translation.
12.Use new Japanese translation.
13.Support post message in Japanese
14.Use new German translation.
15.Fixed incorrect CPU Vcore when set to above 1.60V
Currently i test 1401 - whooah ;) will show you dual core fsb tommorow ;)
Could you please post a changelog, and more important, a download-link? That would be very nice!
are you firewire on hardwaredeluxe forum Lotzi ? ( ya specs are similar )
on a note pmp did share us the changelogs before, bios itself is something different ofcourse as i tneeds to undergo testing by them....
im having truble with 6850 and my dang striker board.
ive tried 1004, 1102, 1202, 1301.
none of them have got me into a bios screen yet
1202 gave me a post screen but no bios...and a cmos error message.
any ideas as to G0 e6x50 support for striker extreme?
mine is an early rev 1.00G btw
very close to ditching this board....but as it was a pretty penny do not really want to...
any help/ideas would be appreciated by me :confused:
i have no problem with G0 ... on my Striker ...
what revision is your striker , and what bios did you use?
i may have to send my 6850 back.
im trying to determine whether my mobo is faulty or the chip
any info you could provide would help me :? :)
i have last revision of mobo, and bios 1301
i think my striker was/is damaged....(particularly the nb chip)
ive taken the battery out..might try 1301 flashy sometime again...i got a p5k so no dramas. bothe the 4300 and the new 6850 i got work well on the new board...so i havent overvolted the 4300 to death....the nb just shat itself....i think i damaged the nb chip while mounting the nb cooler.
your replies are appreciated tho' ...
i thought there was a 1.03 or 1.06?? cant remember.
I heard rumours of an 1.03G or something but never saw that on a piccie... but I think pmp is correct only one official rev (print on the board), but some differences in the heatpipes ... and countries of fabrication maybe
The only versions that I have seen are;
1. Taiwan manufaturing number is 90-MIB140-G0EAY00T.
2. China manufacturing number is 90-MIB140-G0AAY00Z and has a different heat pipe setup.
Both have 1.00G designations printed on the motherboard.
Victor wangs results are here somewhere with the new Quadcore GO at almost 500mhz with the latest bios on the Striker on air cooling !!! so the board is taking huge steps forward with the latest biosses...
Damn I got ripped of on Ebay , won me a QS6700 dirt cheap, payed the guy ( had several good user reports) now got an email by Ebay that they removed the seller as he seems to be doing some frauds ( maybe one of the reasons he didn't accept Paypall)They must be correct as I get no longer response on the mails... sad peeps around ... very sad...
I've only seen two Striker Extreme's, but the revisions seem to be the same 1.00G but one of them has an extra heatpipe closer to the RAM slots. Which actually gets in the way of some HSF so I'm not impressed.
Otherwise I personally have not seen other board revisions besides the mentions 1.00G.
I bought the Striker when it was first available in Canada, and it only has the lower heatpipe closest to the RAM slot. With my older OCZ Special Ops PC6400, I managed to get 1750 MHz FSB.
I haven't tried anything else since I bought better RAM and newer BIOS's, because I'm waiting for a Q6600 G0. I also have yet to test stability with 4x 1GB OCZ.
Well 1302 bios improved quadcore overclocking, if they can up some more FSB on the new 1333FSB CPU's, that would be nice.
I read some other posts concerning the latter cpu's that newer biosses resolve new FSB holes... anyway the Striker board is maturing fast now... :clap:
Not yet.I found some troubles with latest 1401/1301, so for now i would advise that it should not be used, as at some conditions you will be unable to enter BIOS without 533/SPD only RAM sticks.
Nothig really, it's still at QC stage.
