Loop tubing length question
How much of a factor does the tubing length in a loop matter? I'm running my pump/res external (since it's an HTPC case) and want to locate the external unit further from the case so it's hidden away. To do this effectively (while keeping the res and pump level with the case) would require about 15-20 feet of tubing (rad/pump to case). Would this cause issues?
I'm toying with an alternate solution that would not require this kind of distance but would look much less elegant in the room but only want to take that approach as a secondary choice.
I also hard Cathar mention something about keeping the radiator low to the ground (I assume for cooler air). I was thinking of this as well but that would place the radiator about 4ft lower than the pump and the pc, would that be an issue?
I'm running the Laing DDC 3.1 that's from Koolance in the RP-1000 unit.
