PA120.3 To shroud or not to shroud ?
I’m going Have a PA120.3 with Yate Loon D12SL-12 120mm fans in the base of a TJ07B-W, and I was Just wondered if any one has tested a PA120.3 (with and without) the shroud fitted using low CFM fans to see if the shroud made any difference to the temps.
Thermochill says this in their FAQ:
For best temps on the PA series, testing currently shows PUSH to be the best solution... shrouded vs unshrouded exhibits minimal benefits, in the region of upto 2%. Fans pushing as opposed to fans pulling exhibits increases of upto 4%, and is roughly equivalent to running a shroud with fans in a pull configuration.
http://www.thermochill.com/faq.html
When I've been looking at threads about Thermochill PA rads, most people seem to use a shroud.
Your views will be most welcome.
1 Attachment(s)
G3/8" O-Ring sealing fittings to use with ThermoChill radiators
Just seen these added to the stock at:
http://www.over-clock.co.uk/
"We're pleased to announce we've FINALLY managed to get hold of stocks of G3/8" O-Ring sealing fittings to use with ThermoChill radiators (and anything else that uses 3/8" BSPP threads that has a suitable lip for the O-Ring to compress against)".
These are in stock and available to purchase NOW at just £1.99 exc VAT each.
I'm goning to order some right now!
