Phase users I need pointers from folks who have successfully been able to set up there
rigs on phase and who have been able to consistently leave the rig folding on a 24x7
basis without trouble.
I have now gone through a total of 11 Mobos and have tried many different tactics all
with the same end result a dead mobo.
First a little about the cooling:
I have used both a near silent Chilly1 with modest cooling potential and the evap temp
holding steady at -32c folding 2 cores.
I have also used a modded Mach II with an evap temp never dropping below -48c (modded by Jinu117
and head replaced with a Chilly style head).
NOTE: The problem does not seem to be in the mounting area but seems to be in the back.
Methods of condensation proofing I have used:
Front: socket filled with Dialectic grease and socket surrounded by armaflex with tight near
airtight mounting.
Back:
A) Armaflex on the backplate.
B) Also tried Armaflex covering entire back
of board (i believe this caused the boards to fail due to heat build up).
C) Dialectic grease layer over most of the back of board and covered with Armaflex
D) Thick layer of dialectic greas and then covered with Armaflex just over backplate.
Note2: No backplate heating element has ever been used.
I have also coated the socket area with dope once but then I bent some socket pins and
could not RMA so I have stayed away from trying this again.
So what am I missing here or is it futile to try and fold 24x7 under phase.
