Commando again! E66 ->100% OC ,88GTS ->Aqua03 @ 226k,3d01 @ 70k+,pics
:eek: :toast: :thumbsup: ;)
One question just to make it clear: Is this still with ONE 8800GTS?
Nice stuff ;) Very sweet pics!
Didn't you try with more Vcore?
Some serious clocks :clap:
Looking sweet! Keep going!
Good work there PCCrim, I especially like how you've rigged up some ghetto mod on the GPU for better cooling, how much of an increase did that give you? and was that 1.75v vcore for the 4.9GHz cpu-z?
We have quite similar setups; E6600, 8800 320 apart from I'm on a mach II, and our scores and clocks are so alike it is scary, even the voltages we use are almost identical.. hehe I wish my 8800 was as strong as yours though! :D I'd be willing to bet you could easily break 36k in 03.
Good job all round sir. :toast:
Maff
its not possible 88GTS @ SLI on Intel chipset :D
yep,i tried 1.8v withou any gain ,the best for that run was 1.75v
GOOD GRAVY!!! Those are sweet scores! Except for 03, it seems low. AT around 3.6GHz, with my vid card as in sig, i get 27k. Seems like your score should be a bit higher than that, based on your almost 20k higher in 01, and like 60k higher in AM3, but i suppose thats because theyre more spu dependant... Anyway, Nice freakin CPU clocks :thumbsup:
no gains :( , at this time the room temp did not help me -->23C and i just did the mod cz with the original 88GTS cooling i can`t fit the Zalman Sink on SB
and i used 1.75v for 4938mhz :)
We have quite similar setups; E6600, 8800 320 apart from I'm on a mach II, and our scores and clocks are so alike it is scary, even the voltages we use are almost identical.. hehe I wish my 8800 was as strong as yours though! I'd be willing to bet you could easily break 36k in 03.
very similar my friend :) and i like very much that new combo
with 8800gtx i can easily get 40k+ in 3d03 and "only" 33.5k seems very low for the clock :(
Yeah I think maybe the 320's are not as strong in some benches (03 and 06 especially) as one might expect. So many variables and not enough data (yet) to see any kind of trend developing, I was thinking that perhaps it's driver related being as it's a new card and all, but thats just speculation. :shrug:
I too have a Zalman on the Southbridge and like you I found it was in the way of the GPU heatsink... but it was nothing a hacksaw couldn't cure :D
http://i135.photobucket.com/albums/q148/JAFFA22/SB2.jpg
Anyways, enough about my setup, good luck with your next bench session PCCrim, I'm looking forward to your next results... as usual :toast:
Maff
:toast: ... Is this another Commando?
good jobs and good results !
here a 3d03 score on P5WDG2 WS Pro ,88GTS @ 660/1040)
http://img228.imageshack.us/img228/2...zgts318qq6.jpg
and 88GTX (670/1000) on P5WDG2 WS Pro + Conroe 4ghz
http://img220.imageshack.us/img220/4...6601000tq7.jpg
GTX beats GTS 320mb by 6000 3dmarks :S
very nice HermS ,i will do the same with my Zalman :D
no, it`s the same Commando-> my second :)
congratz mate.. :) very nice results!! :)
:woot:
tnxs for sharing.. :)
PcCI2iminal @ Νιce setup , pics , results .
Now switch off this 6600 with your quad on commando for a second round :D
