Make your own UV Dye, And make it any color.
Most of you might already know this, but here you go.
Get a skinny good brand highlighter and pull out inside. Cut a slit down it and place into a quart of distilled water for one hour.
Then pull out cotton or the left over fabric.
Then let it sit for 24 hour before using.
Then take another quart container(powerade bottle) and fill 3/4 with distilled water. Then add about 5 or 10% of the orginal mixture of dye into the quart of distilled water.
Keep the orignal mixture for later batches. Just remember to cut it later with distilled water.
It is super bright and during the day its clear. Thats the cut mixture. The orignal of course is much stronger.
Here is a pic of the made solution before you cut it.
http://www.chadandjodi.com/watercool/greenuv.JPG
Poor mans UV Dye. Wow is that stuff bright.
Any one tried this??
