Lian Li 201b/Carbon Li
Casemod for Point of View.
Translation courtesy of frenkie.
The sponsors
http://need-modding.nl/logos/povtranspa.gif
http://ediejo.nl/Logos/pov-tagan.gif
http://need-modding.nl/logos/CorsairLogo2.gif
http://need-modding.nl/logos/Innovateklogo.jpg
http://need-modding.nl/logos/logoa.jpg
http://ediejo.nl/Logos/freezing.JPG
http://ediejo.nl/Logos/revoltec
Specs
Graphic cards: Point of View 8800GTX sli
Power supply: Tagan TG1100-U95 1100W
Memory: Corsair Dominator TWIN2X2048-8500C5D
Mainboard: Nvidia 680i
CPU: Intel
Cooling
Cpu, Graphic cards & Hard disks will be watercooled by Innovatek
I dismantled the case for a large part. I will start the topic beginning with the dismanteling of the last part of the case.
The lower part for the 12 HD’s has been removed.
http://ediejo.dnrhosting.nl/Casemods...i201b/pov1.jpg
The parts that will be used again.
http://ediejo.dnrhosting.nl/Casemods...i201b/pov2.jpg
Solid door. Comes in three parts.
http://ediejo.dnrhosting.nl/Casemods...i201b/pov3.jpg
Last headstock nail drilled out.
http://www.ediejo.dnrhosting.nl/Case...i201b/pov4.jpg
http://ediejo.dnrhosting.nl/Casemods...i201b/pov5.jpg
Not much left this way.
http://ediejo.dnrhosting.nl/Casemods...i201b/pov6.jpg
This part is nice to work on, I have all the space I need. Thinking about the stealth part which will be used in this case as well.
http://ediejo.dnrhosting.nl/Casemods...i201b/pov7.jpg
And the rest of the casing completely disassembled.
http://ediejo.dnrhosting.nl/Casemods...i201b/pov8.jpg
The case bears the theme Point of View.
One sidepanel will bear the Point of View.logo airbrush.
http://ediejo.nl/Logos/POV.jpg
The other sidepanel will get a double windowframe with pieces of text, which also will bear the Point of View. theme.
Other materials that will be used. Aluminium for the stealth part. Several sorts of plexiglass.
The rest of the case will be polished or chromed.
I can start with the carbon.
http://ediejo.nl/foto's/LianLi201b/carbon1k.jpg
http://ediejo.nl/foto's/LianLi201b/carbon2k.jpg
http://ediejo.nl/foto's/LianLi201b/carbon3k.jpg
I workout some idea’s about the carbon. So I will make a cover plate for the drive bays. I do not put the led's like in the stacker810. I did that before led's in the coverplate. (see the stacker810) When i do that againg the concept is not originel in my eyes. ;)
To cover the DVD-ROM and the reservoir for the water-cooling. The bezels will be change for carbon. Also the mainboard tray will be carbon. And some more parts will be covered by carbon.
On the bottom from the case and on the part what separate the case in two parts there I will put white plexi. To let the outside colour come back inside. I hope I can make my own radgrill from carbon for the dual radiator in the top from the case. To let the inside come outside.
At the door there is a part of black aluminium that will be chrome. Now I have 3 colours White Carbon and Chrome.
2 from the 3 colours are coming back in the watercooling.
For the CPU from Innovatek the G-Flow
http://ediejo.nl/Fotos/LianLi201b/watercooling/cpu.jpg
The VGA cooler.
http://ediejo.nl/Fotos/LianLi201b/watercooling/vga.jpg
And I do something with the cooler. The black part will be covered with carbon. The aluminium part will be chromed. So that it fix with the CPU cooler.
The reservoir the black fass-o-matic from Innovatek. That comes in the carbon plate behind the door.
http://ediejo.nl/Fotos/LianLi201b/watercooling/res.jpg
I have also 2 x 120mm radiators from the Msi. By one the aluminium part will be chromed and the other one will be black. The black one comes in the front at the bottom from the case. And the chrome one comes behind in the case.
http://ediejo.dnrhosting.nl/MSI-Cebi...-777/msi40.jpg
At the bottom part from the case everything will be black because the watercooling for the hard disks are also black.
http://ediejo.nl/Fotos/LianLi201b/watercooling/hd.jpg
And the power supply is also black.
http://ediejo.nl/Fotos/LianLi201b/psu.jpg
The casefans are also chrome with white led’s
http://ediejo.nl/Fotos/LianLi201b/80120mmfan.jpg
I order also some led’s by Ledsee
White one.
http://ledsee.com/components/com_vir...292e8e9fb4.jpg
And purple one
http://ledsee.com/components/com_vir...91c72a6916.jpg
I think about purple light at the bottom part from the case and white light in the top part. Ore the hole case purple. Let me know what you think about it.
