Originally Posted by jokester
I've got my 680i and QX6700 Prime Stable as 3.6GHz using 1.575V in the BIOS, this droops to about 1.475V with all four cores fully loaded with temps about 70C (on water). Now I can live with that as it'll rarely see that sort of loads in normal use.
The problem is though that the Vdroop increases with the number of fully loaded cores. So the problem I've got is that with one core at 100% the droop is only down to 1.515-1.52 which means with only one core loaded it reaches 70C as well.
