Gigabyte DS3 FSB Wall between 420-430
I have a Gig DS3 rev 2 board that seems to run out of FSB at 430 no matter what ram I have put in, or BIOS version.
- I am currently using Crucial Micron D9GMH Anv. Ed. from New Egg.
- I have tried F4 F5 F7 F8A BIOS and no luck.
- I have tried all the volt and mem timing tweaks, too. I can he 7x428, bu no higher.
- I have even tried 6x, but nothing.
- I can also run the system mem with 2.5x mem @1000+ @4,4,4,10, but FSB will not budge past 430.
- I am aware of the D9GKX problem that Anandtech mentioned at 460 up, but others with Micron D9GMH seem to have no trouble. Am I missing something??
- I have a tons of fans and low case temp. I have also tried pulling battery, etc.
Is this a bad board? My RMA window is closing very soon!!
Please help!! This is killing me!:confused:
http://www.anandtech.com/mb/showdoc.aspx?i=2854
Is this really a D9 problem?
I thought the D9 problem was with D9GKX @ 460 +and not D9GMH at 430 . Others seem to hit 1000+ with D9GMH.
Is it possible that this is an P965 chipset issue?
Got the same problem with P5B Deluxe.
No matter what - just does not go over 427MHz
even with NB@-14C
mem = Corsair 8000UL
Your ram is 5.0-4-4-9 Micron D9DQT (BT-3). You should be able to hit higher, although I am not sure what those top out at.
Are other boards having the 420-430 barrier with D9?
425 FSB on Gig ds3 and on asus pb5 deluxe
Well I finally got a P5B deluxe and I am still hitting a wall at 425-430 FSB. WTF?
Why cant I hit higher FSB?
I can run my memory @1000+, but the FSB will not budge past 420s.
Is there such a thing as CPU limit for FSB?
Please help!
e6300
crucial 10th annv.
