Solid Containers In P5B Deluxe
Good job specially like the chipset cooler. Planning to sell one like that? (spain, so we are near :P)
the machine shop you use must be reaaaaaaally good!
The CPUs pot is very tall!!! the max lenght they could get on my pots where 20cm!
Since you go into the trouble in making solid pots id suggest you make the tube walls larger, like you did on the NB pot
:woot:
Originally Posted by mattstrike3
Or the shop you use is really bad and his pots are just the Norm ;)
Nice setup Crazy can't wait to see some #'s
lol yeah, maybe that to!
can`t wait to see the results ;)
Nice job, mate :toast:
The height is 23cm and the NB is less 5cm. ;)
They are the 2 of the same thickness, but the cpu container it is opened in top to be more easy to put ln2
Thanks :D
Like Crazy said i opened the top of the cpu container.
The containers are simply done in the best shop that is around my zone i like perfection , about the chip7 cooler that one was made specialy for my friend :)
Now crazy lets see some mhz :P
Insufficient insulation IMO on that mobo
nice nb container, are you gonna use Dry ice? ln2? both?
Ln2 in Cpu and Chipset :D
Thanks :D
excellent!
Somebody knows if the E6700 has coldbug? I go to use ln2. :)
Regards.
Intel chips (new ones) do not have it :)
mobo can have cold boot problem , but this can only be on -128°c ;)
or not...
in Portugal, an user has a X6800 with coldbug at 0ºC :S
I want see the video :D
Força com isso!
Originally Posted by PallMall
why not use a little wrap of paper and put dryice on it, for the chipset...
it works ;)
right on the aircooler you mean? i think maybe ive seen that before you got any links?
Nice chipset pot! I was thinking to dot the same thing some time ago.
or not...
0C sounds more bios erroring as it may not be able to read under 0C and swaps to a higher temp.
