Apparently there are some illogical outlets that were attached to my computer circuit. One of these outlets was especially old and had a bad (high resistance) connection. While the circuit is running at 17A on a 20A line, this outlet with the bad connection apparently was arching and managed to entirely burn out the interior of the outlet along with 6" of insulation on the hot and neutral lines, and vaporizing the ground. It was undiscovered (didnt trip the breaker or GFI) till I tried to plug a vacuum into this obscure outlet and my fingers were mildly flashburned when I inserted the plug into the receptacle.
Couple of burned fingers aside, I sure am glad I found it in this manner rather than coming home to a pile of ashes, or worse, it start while sleeping.
Moral of the story, make sure any high demand circuits with plugs in series with each other have good solid (low resistance)connections throughout. Overloading isnt the only way to start a fire.
