XTREME budget RAM *F2-6400PHU2-2GBNS* 1x2GB 4-4-4-12 @ 933mhz w/ 2.35vdimm $$148.49$$
Well I gotta say, this is pretty sweet.
I was playing around with the cheap G.SKILL at newegg, and man it isnt bad! Usually on XS you see the best-of-the-best, but usually it costs an arm and a leg... or you are stuck with absolute cr*p ram if you try to save a few bugs... here is a good in-the-middle. Its screaming "im not micron" but at 150, who cares? I mean, really... decent D9GMH costs 250-300 and runs just a hair faster @ this voltage? TALK ABOUT VALUE!
Anyway, im just impressed!
http://www.newegg.com/Product/Produc...82E16820231071
It only liked up to 2.35vcore, no more. I didnt spend a TON of time trying to get every last mhz out of it, just set 4-4-4-12, and everything else on auto. Cranked it up to 950, failed prime, backed off a hair to 933 and has been rock solid. This was tested on a DFI infinity 975 mobo.
I dont know what the IC is, they are rebranded G.SKILL, maybe GS TECH can fill us in.
Anyway, Ill shut up now-
http://www.importjdm.com/shipped/gskill.PNG
