Trying to get a set of Mac Pro heat sinks
I am looking for the best cooling solution for a dual socket 771 setup that is also relatively quite. I recently put together a dual Woodcrest system and I am trying to find a good cooling solution for it. Currently I have the passive 2U retail heat sinks installed and I have a pair of these. The problem with the Dynatrons is that they sound like jets taking off. Since this is going to be sitting under someone’s desk they can’t be used.
I know that the new Mac Pros have some good heat sinks and would like to use them if I can find them. Anybody know where I can get them?
Anybody have any other suggestions on a good heat sink that can fit in a ATX case.
