Overclocking on P5B-VM
Hello,
i try to overclock an E6600 on a Asus P5B-VM with 2x1GB DDR2-667 Infineon, but i do not get past 270MHz FSB.
I changed the mem to DDR2-533, fixed PCIe-Freq to 100Mhz, tried severeal vcores and mem-voltages but no success. Everything above 270mhz fsb and it won't even post.
The cpu and mem can at least run with 333mhz fsb, ddr2-667 @ 3.0Ghz on a P5LD2-VM SE with standard vcore and mem-voltage and a pcie-freq of 116mhz.
Anybody else with problems on a p5b-vm or any suggestions?
Post some screenies of your bios setting would be very helpful.
Ok, here are the screenies:
FSB set to 333Mhz (CPU is able to handle this), DDR2-533 just to be safe, PCIe set to 100Mhz... i have even tried vcore 1.4V and Mem 1.95V
http://www.wilke-service.net/gallery...d_Settings.jpg
I left this settings @stock but i also tried disabling all energy-saving-features.
http://www.wilke-service.net/gallery...figuration.jpg
P5B-WM owner, Take a look in this thread if you are irritated about the bad OC-feature on this mothercard... :confused:
Maybe together we can write something to Asus! :slapass:
http://www.xtremesystems.org/forums/...=122122&page=2
