Hi,
I read the sticky and it said that bleeding with a T-line can take several days... I just want to make sure I'm doing what I can to accelerate this or not prolong this.
Here's my loop:
T > DDC #1 > DDC #2 > Rads > Blocks > T
DDC #1 has alphacool top (modded top inlet) and alphacool res
DDC #2 has alphacool top only (no mods)
I'm using 10:1 Distilled:Pentosin.
I've got the loop fairly full of coolant. I've been running it for several minutes and any air that was in there unfortunately now is in the form of tiny bubbles. The DDC pump with res makes for a nice frothing machine. I'm starting to regret using this res as per popular opinion, but would like to try and make it work now if I can.
When I stop the pumps the tubes are like 1/4 full of tiny white bubbles and 3/4 full of blue coolant. I think there is a lot of air in there still but it's all tiny frothy bubbles which is going to be incredibly hard to bleed out I'm thinking.
Do I just keep this running now? Will the tiny bubbles eventually bleed out of the T? Is there anything else I can do?
