P5B Deluxe + TT Big Typhoon - backplate won't fit
I am gonna assume you guys with the TT BT don't use the backplate for it?
Cause it won't fit on mine...
There's the little metal bits sticking out under where the backplate would go, so i can't imagine smashing them with the plate would be a good idea.
So just screws is okay for support in the back?
TTBT / DQ6 with Crazy Cool
Not the same board, but similar concepts. I was preparing a guide and have many photos. Would have published, but DQ6 since died.
Anyway, see pics for plastic standoff of appropriate size. Note problem with clearance to MB tray - resolved with plastic washer (1mm) on each MB standoff. Rear connectors still fit. Note additional problem - bolt heads touch MB tray (will fix with replacement M3 countersunk bolts to replace the round-head bolts supplied).
[EDIT] Full guide: Gigabyte GA8i965-DQ6/DS4 & ThermalTake Big Typhoon - GUIDE - http://www.xtremesystems.org/forums/...d.php?t=114193
http://www.xtremesystems.org/forums/...1&d=1156729349
http://www.xtremesystems.org/forums/...1&d=1156729691
Food for thought ;)
Cheers
