chip has been alive only an hour or so ....only 1.5v so far
http://img124.imageshack.us/img124/2039/35ghzah5.jpg
for £83 amd are giving me the golden chip i waited for :toast:
WHOA!
Is that a waterchiller? For a B1 stepping and the associated coldbug, nice temp control!!
Any benching done yet? :D
Nice!
custom single stage
coldbug like crazy when idle but as long as it's loaded it seems happy so far - not like my opty 148 which just gets crazy period.
i'm thinking rebadged fx-57's perhaps for only 1.5v so far ...real nice :)
i got the chip for a htpc coz i heard they were clocking to 3ghz stock volts but figured i should put it under the cold and see how it goes....phase has been sitting there for awhile coz i got sick of coldbug......now i need another chip for the htpc lol
Looking awsome mate, dont supose you seen what it can do on Water or Air cooling mate.
What's the full stepping, and where did you get it from. Nice oc btw!
from what i've seen of other peoples they will do 3ghz @ stock volts on air...same stepping.Quote:
Originally Posted by 4Qman
stepping is kab1e 0626fpmw
i've got his brother coming tomorrow so i will see what stepping he has and whether he is as strong.
That higher multi is a godsend, ss per loc.o's advice in the opty thread i'm going to try thr ricky tweak to see if i can get above 330fsb with my 146.
that tweak helped my 148 somewhat ....that and putting the ihs back on.
under a stock vapo it was ok but after NL11F mod & 402 regas it was too cold for it and it bugged like mad whether idle or load over 295-300htt
this chip seems to be more bug friendly.
very nice chip you have there...got to love them cheap gems now. i also just saw the thread on you SS...nice little setup you have there and it looks like you are getting the CPUs you need to push it now ;)
keep it up mate.
a little update
time is a bit slow because of the ballistix ....i'll throw my redlines in there later and give it some more volts too.
http://img209.imageshack.us/img209/7676/360016vyp7.jpg
sweet deal huh? lol gunna pop the top apply some as5 and put it back on?
very nice :D
mmmm maybe :DQuote:
Originally Posted by i found nemo
looks sweet for this price. maybe there will be few chips without coldbug and we see 4 gig on a non-fx in the end :)
but for single stage this is truely great clock. some benches would be nice ;)
