ASUS P5W-DH: Pulling My Hair Out
This board was good to me at first but recently it's been going downhill fast.
First couple weeks it worked excellent, nothing wrong.
When i put a Pentium D 950 in, it started acting crazy. SP2004 Large FFTs would fail at stock speeds, when overclocked past 250 FSB it went insane. CSS ran at double speed, programs crashed even if it was priming, but usually prime crashed instantly. This is with plenty of volts.
It randomly restarted and those problems went away, and i went on to get a normal overclock of 4.4 Ghz 24/7 stable on it.
Then it went back on the fritz. My CD rom drives stopped showing up in windows. I played with the IDE settings for hours, nothing. After reading some Microsoft guides, it seemed that the registry was messed up, i tried to fix that, but to no avail. The next time i restarted i lost my mouse.
So i'm stuck at the computer with no working CD rom drives and the mouse isn't working.
I took my hard drive out and put it in my AMD system and attempted to repair the installation. No good, it would reboot infinitely without finishing. Put it in another computer: same thing. So i reinstalled XP and "kept the file system intact." And then put the hard drive back in my ASUS P5W.
Messed with it for another hour, USB keyboard/mouse would work in the BIOS, but upon entering windows the keyboard would cease working and the mouse would go dead. Eventually it started working.
Back in windows, repaired installation, still no CD rom drives, but at least my mouse is working. I started messing with the CD Rom drives again and found i could get the BIOS to recognize my DVD burner! But only sometimes... i could restart and then it wouldn't be listed in the BIOS. It's that retarded. So i flashed the BIOS. Go back into windows... no CD Rom drives.
Back to BIOS, tell it to boot from CD. It finds my DVD burner, starts booting up the Windows XP installation. I mean to do a full format this time. It starts reading from the CD, goes for like 3 minutes collecting files, and then BSODs. I attempt again about 4 times, BSOD everytime.
Use the computer for an hour, decide to OC back up to 4.4 Ghz. Go into the BIOS and the Vcore options are gone. Whatever, use teh computer normally and it says i have 30 days to activate windows. Restart, says i need to activate now.
Let me recap those problems
1) Problems with Memory & Large FFTs @ stock
2) FSB problems past 250 FSB that magically fixed itself
3) CD Rom drives will show up in the BIOS sometimes, sometimes not at all, and never in windows
4) USB would work, and then not work when i got into windows, magically fixed itself eventually
5) Did a 100% proper BIOS Flash (i've done it like 6 times now) and STILL it took away my Vcore options
6) I can't even reformat it because it BSODs a few minutes into reading off the Windows XP disk
I used to recommend this board, but my day has been hell.
HELL.
Stay away.
Edit: Maybe i'm just unlucky so don't base your buying decisions off this completely, when the board is working right (and it WAS working right) it's a damn fine board, but i've had TOO many separate issues with it to be able to recommend it anymore.
