Originally posted by Arky
full loaded, m8 it's not that simple ! it's even simpler :D just get them to fill it with r404a thay did it with a bottle of r404a and a set of dials, (you need them to fit a valve bolt on one, two minute job) then you keep letting very little amounts out to get the best lowest temps also the compressor isn't freezing around the evaphead pipes base to much :)
Hope this makes sense Arky
Karatekid, do you think my evap to core need reseating ??
you said you let 40gram in.
