Pumps: Iwaki or MCP655 (D5) for my Dual PA120.3 Loops?
Hi,
I am going to be buying two pumps soon, for my two loops. The loops are going to be identical PA120.3 (with shrouds and a push/pull 6 fan setup), one loop for my CPU, and one loop for my GPU('s). They will be seperate loops, of course. For the CPU I will be using a Storm Rev. 2 waterblock, and Maze4 water block
One other thing, is the loops aren't too restrictive, considering I won't be putting CPU+GPU or more on the same loop.
Now, I had orignally planned on getting an Iwaki MD-20RZ, but thats $180, and there is no way in hell I want to spend $360 on pumps alone. I am quite adement that I don't want to spend over $250 on pumps.
The Iwaki MD-20RZ (too expensive) has these specs: Iwaki MD-20RZ Japanese high pressure rated pump. 5/8 inch hose connection on inlet and outlet. 1/38 HP Motor output. 3100 RPM motor speed. 0.53 amps. Max flow 2.9 GPM. Max head 22.6 ft. Max system pressure 14.22 psi.
The Iwaki WMD-20RLT (barely affordable) has these specs: Iwaki WMD-20RLT American motor pressure rated pump. 3/4 inch MPT inlet and outlet. 1/38 HP Motor output. 3100 RPM motor speed. 0.48 amps. Max flow 8.2 GPM. 378 GPH at 6 feet of head. Max head 14.0 ft. Max system pressure 9.95 psi.
Now, Maxxracer said this "The MD20RLT will also work, providing temps roughly .1 c higher", and that being said, the specs are so VASTLY different between the two Iwaki's, I have reason to doubt, can anyone give me more information on this?
So, now onto the second part of the post, the smaller pump options (MCP655 (D5)). I'll be quite frank, and state that I really don't much at all about the smaller pumps, because I never had to consider them before.
So, as far as I know, the MCP655 is the same as the D5. Is it worth considering in my loop? It seems almost as good as the cheaper Iwaki, and is a LOT cheaper.
Last question, what about Eheim? Any good?
It's not that I don't have the money, its that I am not willing to spend it. I already spent $340 on Thermochill stuff :)
Thanks,
Yan
