It is a WR ?
validation
DDR642 1m
http://simon.webideal.ca/Bench/ballistix%20321%201m.JPG
DDR626 32m (working on DDR 630)
http://simon.webideal.ca/Bench/313%2032m.JPG
It is a WR ?
validation
DDR642 1m
I am not sure if it's a WR... I kind of remember one slightly higher. However, that is one HELL of an overclock.. very nicely done.
What's the highest 3D stable you have been able to do? Would you mind doing a Sandra Buffered test?
i'll try sandra and 3d....bbl
For X2, you need to complete 2 spi runs for it to count, since you're only stressing half of your memory. Just feel the difference when you touch the heatspreaders.
Thanks a lot Supertim0r, that is one impressive overclock! That's some sweet bandwidth :D
Let us know if it's 3D stable over a period of time. :toast:
Unless you don't plan to keep that overclock.
Thanks Deathspawner :)
I do not plan using the memory @ 3v. I should receive a new set of Ballistix 16TD1 friday. If i'm lucky, i'll have my SS gased this weekend...320x10 :eek: :D
woah dude nice clocks, mind benching 05 for me?
I'm going to gym right now, i'll bench 03/05/06 when i'm back.
btw...32m updated -> DDR626 :)
edit : DDR642 1M
:confused:Quote:
Originally Posted by thunderstruck!
there's only one memory controller.
two sPI runs is more for if you're stressing the cpu.. which has two cores ;)
this is what I was thinkingQuote:
Originally Posted by ozzimark
I'll see if I can run dual PI tomorow (after the AC is installed :D )
Then why does mem get a lot hotter when running 2x pi, rather than one? And why am 1x32M stable at a higher speed or less vdimm than 2x32M?Quote:
because you're stressing the ram more with two instances of superPI (which means what you said is right in a way, it's just usually a cpu stress thing to make sure both cores work properly)Quote:
the only reason two isntances of superPI doesn't stress the ram more with a single core is because only one instance gets cpu time at once.. so there shouldn't really be a difference, other than the run takes a LOT longer
He's using an X2 3800+.Quote:
i know.. i was just going on a tangent. :fact:
hey thunder,
correct me if i'm wrong...16TD1 is the new rev without the death syndrom ? (I have a brand new set coming)
Try with multi 8x , ori 10x :)
A tangent? You? No :rolleyes:Quote:
:D
Yeh, it's the new one. have had mine for about a month now. 300Mhz 3-3-3-8 at 2.73v.:)Quote:
Originally Posted by Supertim0r
any idea what's the WR 2gig 1m/32m ?
Is it up to date ?
":: Athlon 64 2x1GB Results
nightic | 2x1GB Crucial Ballistix Z503 - Micron -5B D | 3-3-3-7 1T @ 307MHz | 2.9v | Link! - SPi 32M Stable: Yes
BRiT | 2x1GB Crucial Ballistix Z503 - Micron -5B D | 3-3-3-8 1T @ 307MHz | 3.05v | Link! - SPi 32M Stable: Yes"
I've had my 16TD set for a good 2 months now, solid 300mhz.:)Quote:
Where does one get these new 16TD1 based modules?
Only 1GB modules I see at Crucial are the Ballistix Tracer modules...?
