Not sure if it's common knowledge yet, but the gingerbread update for the Atrix seems to have been released today. Seems prettier and faster. Lots of new look and feel changes and improvements!
--Matt
--Matt
Definitly not as stable as 2.2.
Ive noticed a bug with google navigation, when you turn the screen off but leave nav running after a few min it will turn the screen on and off rapidly until you turn it back on or exit navitation. This is only when turned horizontally. Could be the mix of stuff I have on my phone such as launcher pro.
Other then that I have just had random bugs that I had to do a battery pull to get the phone back to normal.
How are you finding the battery life on 2.3.4 as compared to 2.2? I just got my atrix yesterday (Bell atrix..unlocked using on rogers) and I flashed 2.3.4 right out of the box. I've been experiencing some mediocre battery life
UPDATE!
I've kept my atrix, and I gotta say I cant recommend this ROM enough. Great battery life, great performance
The battery life was abysmal initially after the update. The phone barely lasted two days for me instead of 3 or 4 like it usually does. It went back to normal after rebooting it though, and has been back to normal since. The removal of the battery % indicator in the settings menu was somewhat obnoxious, but there are apps for that.
--Matt
Such a cool phone
I've had CM7 on mine for a while now. Much better than what Moto has produced for it. Substantially faster, especially when scrolling and zooming.
--Matt
I've rooted my Atrix running 2.3.4. I got a notice about an update to 2.3.6, do I need to unroot my phone to apply it?
