Benchmark results very low on 4770k
The estimated time remaining for all FAAH tasks on my 4770k are very high. At the moment they show as 03:27:01 and that is about 3 times as long as it actually takes to crunch the wu.
On my other rigs the estimated time is about right.
As soon as I increase the work buffer above 1.5 day I start getting wu's running in high priority.
I have been searching for a fix but can't find it.
The only thing I found so far is the difference in Benchmark results on my rigs. The results for the 4770k look all wrong.
Is there a way to fix this?
i7-3770 @ stock
Benchmark results:
Number of CPUs: 8
3710 floating point MIPS (Whetstone) per CPU
14239 integer MIPS (Dhrystone) per CPU
i7-2600k @ 4500 MHz
Benchmark results:
Number of CPUs: 8
4230 floating point MIPS (Whetstone) per CPU
16122 integer MIPS (Dhrystone) per CPU
i7-4770k @ 4300 MHz
Benchmark results:
Number of CPUs: 8
1573 floating point MIPS (Whetstone) per CPU
10614 integer MIPS (Dhrystone) per CPU
