Originally Posted by
Utnorris
Air in your rad will cause some flow issues. I had a similar issue a while back, turned out my block was gunked up, but also had some air left over in the rad which caused some weird noise and flow issues. If you can shake it, try that or tip it back and forth. A D5 on just a CPU block should give you over 1Gpm easily. I was running cpu, two gpu's and a MB and was getting .56 GPM, so you should get 1 GPM easily. By the way, I swapped out my dual D5 for dual MCP355's and saw an increase in flow. Also, getting higher flow didn't help my temps, but it did make me feel better.
