I'm setting up a friends system with a DDC-2 w/ Petra's top and after about 5 min. the pump becomes intermittent... it stops, starts, stops, etc. The pump is brand new.
The pump is upright supported by two large rubber posts under the stock mounting tabs.
I felt the underside and noticed two things...
a) it was damp... coolant is somehow leaking into the pump and out the bottom? I haven't taken it apart yet, but will this evening. Both barbs are dry as a bone. BTW, the o-ring was installed and the screws tightened appropriately. (I have 3 other DDC pumps so I'm not a total noob).
b) it was extremely hot... like I nearly burned my finger hot.
This is clearly another bad DDC-2 but I'm guessing an atypical failure type?
Has anyone else noticed this in the past?
Anyway, chalk this up as another DDC-2 failure. It looks like NCIX is stocking the 3.2 so I suspect that will be the replacement... let's hope it fares better!
