http://images.cardomain.net/sites/so...2_4ohm_dvc.gif
which audio option here would kick harder, 1 or 2?
also wut kinda exclosure do i want, a Small Vented Enclosure, Medium Vented Enclosure, Large Vented Enclosure?
if you dont tell which subs are you using wit ohms rate and wattage and amp specs i cant tell
sorry i was going to get these:
2x Kicker Comp VR CVR124 Subwoofer - $149.95 /w free shipping
- 12" Dual 4 Ohms • 400W RMS / 800W Peak
ok let me explain picture 1 you need a 2ohm stable amp pumping 800w rms @ 2ohm
picture 1 you need a 2 channel amp pumping each channel 400rms at 4ohm or near it
i would go second way you dont stress the amp
thanks, also wut kinda amp could i get (max watt)
dont look at max wattage, that's pointless, look at the RMS/ohm watt ratings, as that is what you will actually be using. you will very rarely hit peak wattage.
you have to move by rms measure peak is useless
let me look for a nice 2 channel amp for those subs
edit
http://www.cardomain.com/item/ROCT10001BD
its mono but thats ok.... its d class amp with almost what you need in power
daaaamn 530$ lol..
thats like 2 checks, but i guess it would be well worth it.
see i dont have the subs, box, or a amp.. so when i get those 2 subs, that RF amp, and a nice box,.. essentially wut else do i need, also recommend some cd players.. my friend had a sony xplode cd player and it kicked his amp /w kicker subs like crazy.
www.sonicelectronics.com try that place, they seem to be pretty cheap
sony sux for car audio pioneer, kenwood, alpine is what i use
those are all pretty much value-brands these days, though high-end alpine are ok.
Brutus 1500D's were going cheap a while ago.
Note your pics at the top are for monoblock amps. If you were using a 2-channel amp the ohm load halves again.
Enclosure type will depend on what type of music you prefer and what you end up with for power output.. and vehicle. A pair of CVR12's in a bandpass box would sound pretty nice, though.
