Best ram for 290+?
Hi there,
i just kicked my old nf3 back into gear and i need to replace the geil 512mb stick of ram with some good stuff, so what would you guy advise for my 2800 clawhammer & dfi nf3?
1gb sticks would be ok, but i would prefer to have 2gb.
i was looking around and it seems tccd is good for 1:1 high htt but it has high latency and there is bh5 that will keep the latency low but will probably top out at 250.
so at the moment im a bit :confused: , looking through the sticky at the top this looked quite good - http://www.overclockers.co.uk/acatal...ce_Series.html (top one)
no budget and if it can be bought from www.overclockers.co.uk, that would be great as they are a short drive for me. :)
Thanks,
the gskill HZ is probably your best bet, but you most likely won't hit 290 with them. the only 1gb sticks that can reliably hit 290+ is ballistix, and they'r eno longer in production so you would have to buy them used in the classifieds. also, tccx and bh5 don't come in 1gb modules.
http://www.overclockers.co.uk/acatalog/G_Skill.html
forget about RAM at 290+ on s754, 270-280MHz is more realistic goal... but even that might be out of your reach since you have Clawhammer.
