How do I setup my loop fans and pump to adjust automatically based on CPU temp?
My current order list is 2 Yate Loon D12SH's 120 mm with an XSPC AX240 and my pump is a MCP655-PWM with the Monsoon Series 2 D5 Dual bay reservoir, I am using the XSPC RayStorm CPU block.
I am only cooling the CPU with this and may add GPU later.
I am not sure what I need to do to kinda make this an autonomous setup that will slowdown or speed up based on CPU temp.
What do I need to add, subtract, change to this to make that happen?
Thanks,
Chris
