U2-UFO Facelift
Hello XS,
I’m calling this project Facelift. This is mostly a cosmetic update to my case, but I just replaced some internals as well. I’ve always wanted to do a work log so this will be my first crack at doing so. I have found that I use my DVD drive less and less, as I mostly download anything I need. Also with the large storage drives we have I have no need to burn anything. I can get by without an optical drive for the most part, and if I need one in a pinch I can always just plug one in if I need to install an OS or whatever. In addition I have not touched the fan controller for years, and don’t see much point in controlling the speeds with a fancy dial, so I’m going to go with a minimalist look with this case. I will attempt to keep my color scheme to Black, Blue, and Silver at all possible. I also plan on going with two 360 Radiators in the near future so this will prepare the case to facilitate easy installation. Also, say hi to the project manager Lily. She will be overseeing each step in the process to ensure a quality result :yepp:
The Photo was taken with an Iphone, and it looks terrible, I'll see what I can do as far as picture quality is concerned.
http://img202.imageshack.us/img202/4320/case1f.jpg
More Updates tonight!
6 Attachment(s)
Received my First shipment today! Its time to build my custom reservoir. This design will be very similar to one I purchased a few years ago from Mountain Mods. It was called the circulator reservoir. Sadly MM no longer produces it so I thought I'd make my own. I found this guide on bit tech, and am following it. This one will be much bigger, and sized to line up with a 120MM Fan Space. I will be mounting it to the top center of my new face that is on its way from Mountain Mods.
5" x 1' Cast Acrylic Cylinder
Attachment 119119
First I covered it with Frog Tape to protect the finish, then Measured to 2.75 inches long and Cut with a Saw on a miter box. I opted to do this by hand to avoid melting the acrylic by using power tools.
Attachment 119120
Attachment 119121
Once Cut its time to sand the edges smooth.
I started with 80 Grit Sand Paper, then 100, then 220, 320, and finally 400 Grit sand paper to give the edge a nice smooth texture suitable for solvent welding.
Attachment 119122
Once I was finished sanding it was time to give it a quick wash with some soapy water, and wiped down with a micro fiber towel.
Attachment 119123
All clean and ready for the next step. I'll be waiting for more parts that will arrive next week!
Attachment 119124
That dog is super cute, and reminds me of my own way back when :(
