5850 CrossfireX OC questions
Hi all. Sorry in advance for the dumb questions. I've done some reading and searching, just looking for up to date info and to save some time :)
I just bought a second Sapphire Radeon 5850 reference card. I haven't really pushed my first one yet (just maxed it out in ccc) or installed the 2nd. I'm about to order a second swiftech komodo full cover block, to use with the loop in my sig (will install in parallel with the first card). The goal is extremely fast daily use. I don't need fan control, since I'm using water and a tbalancer.
I want to oc both cards, increase voltage, and retain powerplay. Is it desireable to flash an unlocked msi bios to do this in ccc with the latest catalyst drivers, or just stick with afterburner?
Is it still necessary to disable ulps for afterburner and the latest cats?
Is it possible or necessary to control ram voltage?
Do I need to take the time to find the limit of each card, or better to keep them synced and find the limit of the pair?
I suppose afterburner to explore, then flash whatever I'm happy with? I'm open to suggestions from all the experienced folks here.
Thanks!
