Page 16 of 23 FirstFirst ... 613141516171819 ... LastLast
Results 376 to 400 of 566
Thread: P55-UD6 socket burn
  1. #376
    Xtreme Guru
    Apr 2005
    Finland
    Quote Originally Posted by Migi06 View Post
    More likely Windows 7 mysterious reboot problems..
    Could be drivers like chipset, audio, GPU etc..
    Powersuply problems like bad contact, rail issues..
    Incompability software..
    My problem is as follows:
    Randomly will restart when I'm about to login to Windows without any warning/BSOD or when playing games (well I have only played UT3 and Borderlands lately basicly and it happens for both of them), sometimes I can play for 1 - 2hrs and sometimes it restarts 3 times in 1hr. No minidumps received but evenlog reports "critical" issues: "Kernel-power" Event ID 41, and basicly means unexpected powerloss or something like that.
    Well here's everything I've tried:
    - Running Windows XP [no change]
    - Reinstall of Windows 7 due to I used a vlited Win 7 copy before [no change]
    - Reverted to default BIOS settings + some increased vcore to ~1.265v and 1.2v VTT to make sure it's not a degraded CPU [no change]
    - Swapped PSU to my backup Thermaltake ToughPower 750W [no change]
    - Stability testing; OCCT PSU tester, LinX, MemTest [OK]
    - Temperatures are fine, not using a comp case, CPU @ 1.4v: 55~59C typical for gaming, 68~72C in LinX, GPU @ 60~75C depending on game (fan @ 61%), mobo sth like 32C.
    - Tried different drivers for GPU, NIC and audio card [no change]
    - Removed CPU to check for burnt pins or bad contact => no burnt pins and all pins seemed to made contact (my eyes after systematicly checking 1156 pins O_o).
    However since it happens mostly when playing UE3 based games I think it's most likely a GPU failure, if it was bad contact or mobo voltage regulation issue of some kind it would more than likely cause errors in stability tests as well. The funny or should I say unlucky thing is that when I tried to give my backup card 8800GT a try then ofc the thing freezes in UT3 after a few mins and basicly broke as after the restart I had white dots all over the bootup dos screens and Windows 7 won't install drivers for it cause it says the device is not workign properly and now it doesn't even boot into Windows with it, damnit!
    Then the only other gfx card I have here is an old 6800GT and playing UT3 is NOT funny with a 6800GT and a i7-860 with very stuttering gameplay at 640x480 and lowest quality (7 ~ 30 FPS) but it's like a video that swaps between slowmotion and fast-forward mode, so it's really a pain to even whitstand running some test sessions for say 3hrs to see if it's not rebooting. However with this card it doesn't ever seem to fail at login, I've already made like 10 successful logins in a row.
    How common would it be to recieve such issue (kernel-power) of a gfx card though? This EVGA GTX 260 SC 55nm is not following standard design AFAIK so it's more likely to happen IMO. In fact I managed to find another user with a EVGA GTX 260 SC that's got this "kernel-power" issue as well but for him it also can happen while browsing web and there were no reports if issue got fixed and how he fixed it in the thread.
    Just dunno if I should buy a new GPU right now or wait for 8800GT RMA to be completed which prolly will take more than a week.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
  2. #377
    May 2009
    Belgium
    Quote Originally Posted by massman View Post
    Doesn't that make sense?
    Pins are attached to socket plastic; pins get hot and heat up plastic. Plastic can't hold heat and melts.
    makes a lot of sense to me =o
    problem solved i guess
    System 1 (mine):
    CPU: i7 920 D0 stable at 4.0 GHz cooled by Scythe Mugen 2000
    GPU: PowerColor HD5850 (950/1250 1.2V)
    Motherboard: Gigabyte GA-EX58-UD5 Memory: 6GB DDR3 GeiL @ 1528 MHz
    System 2 (gf's):
    CPU: i7 920 D0 currently at 4.2 GHz cooled by Noctua NH-D14 (needs more tweaking/testing)
    GPU: Club3D HD5850 (awaiting OC)
    Motherboard: Gigabyte GA-EX58-UD3R Memory: 6GB DDR3 Corsair @ 1600 MHz
  3. #378
    Xtreme Guru
    Apr 2005
    Finland
    In my case it turns out to be GPU clock instability lol. I've run these clocks at over 6 months perfectly stable and then suddenly it starts rebooting at them? Normally I would expect seeing artifacts or bsods if GPU overclock stability degrades, not getting random reboots without any warning and "kernel-power" issues. I ran UT3 for like 4hrs without a prob already at standard clocks which hasn't been possible the last 1˝ weeks.
  4. #379
    Jan 2007
    Portugal...
    safaxs, how did you checked the contact between both parts?
    Quote Originally Posted by To(V)bo Co(V)bo View Post
    This is gonna be way more fun than my wifes tits.
  5. #380
    Mar 2003
    Holland,MI-USA
    Yes there was a problem with the manufacturing of these sockets but I don't believe it's exactly what they are saying. Look at the socket and exactly how the pins make contact. If you notice all the contacts around the outside of the cpu socket point inwards, leaving the only way to make contact for the outside edge to be made by the little straight piece of contact that moves and raises to contact the cpu right next to the angled pins(this is what puts the dents in the bottom of the cpu not the angled fingers). I marked a pic with red on the pins that I am talking about. If it was as they are saying that after the cpu heats up the plastic is warping, making the angled fingers loose contact then there would not be any issues before the combo is even ran pins would all make contact and then start loosing contact as the parts heated and warped. Don't settle for the answers they are giving us at this point and time.
    Attached Images Attached Images
    Cooler Master 110 case w/window and cold cathode/Sony E540
    I7 920@4.4Ghz 210x21 Megahalems
    Gygabyte GA-X58A-UD3R
    OCZ 6Gb DDR3 1600
    XFX ATI 5770 960/1400
    Seagate Barracuda 1.5tb
    Lite-On DVD RW iHAS220-08/Sony Optiarc AD-7190S
    PC Power & Cooling Silencer 750
    That's my 2008 Street Glide.
  6. #381
    Champion
    Jan 2007
    The good news is that the new P55A series from Gigabyte has LOTES socket. Let's freeze them !
    Born to lose, live to win!
  7. #382
    Mar 2003
    Holland,MI-USA
    So after doing a lot of looking at the pics I have a few questions that you guy's will be able to investigate. I attached another pic and marked areas of concern. The area that is marked you can see little impressions where the ejector pins of the tool that produced the socket are sunk into the part. (pins are to long or the part was ran to fast causing the pins to push into the part and this would cause distorted/warped sockets) When this happens ejector pin flash is not far behind. Any flash in this area would cause the cpu not to sit properly flat in the socket making it harder for the pins to make contact. I can see flash on the top left but I'm not sure how close the cpu is to the these pins (top left and right)
    OCZ 6Gb DDR3 1600
  8. #383
    Apr 2006
    Sao Paulo | Brazil
    After big delay, last friday received my Core i5 750.
    To be sure that nothing was wrong, before I did a contact test between pins and CPU socket. I fit it with my water Block, for few hours.
    I dismantled them and made these pictures HIRES in MACRO.
    Notice the circled areas, which are the marks mess electrical contact...
    Well, I am now terrified!
    CM 690 II Advanced - - ┐ ┌ x6 1055T @ 3.7GHz - - ┐ ┌ Asus M4A89GTD Pro/USB3 ┐ ┌ Corsair Dominator 4GB 1600MHz C9 ┐
    HIS Radeon HD 5850 1GB ┤ ├ XFX 850 Watts modular ┤ ├ Seagate Barracuda 1TB -┤ ├ Seagate 320GB 2,5" - - Hotswap - ┤
    └ ACER - Aspire AS2920 - ┘ └ Intel -- C2D T5550 -- ┘ └ Kingston -- 4GB 800MHz ┘ └ Intel X3100 256MB 12,1" WSGA - - ┘
    Desktop Intel: GMC R3-Corona Watercooled | Asus Ramapage GENE II | Core i7 920 Rev. D0 | G.Skill Trident 6GB 2000MHz | XFX GTS250 1GB + MCW60 Rev. 2 | Corsair HX620W | Seagate 7200.12 1TB | Samsung 2232BW 22"
    Mobile PC1: Acer AS2920 | T5550 | 4GB DDR2 800 | 12,1" WXGA | 250GB | X3100 | WebCam 1.3MP | DVD-RW 16x | MS Notebook Mouse 3000
    Pocket PC Phone/Office: HTC TyTN II | WI-FI | GPS | Bluetooth |3G/GPRS/EDGE/HSDPA/UMTS | MicroSDHC 16GB | QWERTY Keyboard
  9. #384
    I am Xtreme
    Sep 2006
    Did you also talke pictures before you had fitted the CPU ? were there no marks on it already ? or doesn't Intel pretest these CPU's beforehand... c'mon lads move on... The issue has been discovered and analysed, with thanks to Massman, SF3D and Raju. It should be corrected in the current range of mobo's...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
  10. #385
    Apr 2006
    Sao Paulo | Brazil
    Quote Originally Posted by Leeghoofd View Post
    No, I didn't.
    But, I have had dozens of Intel CPU (775, 1366) and don't saw this marks before. If Pretest or not, I don't know. But no marks are visualized before.
    By the way, double marks in contacts, is not caused by two pins contacting the same electrical contact into CPU, like a afraid. It makes when the pins is bended over fit pressure (probably).
    I "discover" it right now, because a tooke some HIRES MACRO pics of older PentiumD 915 and Pentium4 531, both 775. And in this are the same marks (double contact) and also, NO CONTACT MARKS IN SOME CPU CONTACTS...
    (I will upload this pics ans post here latter)
    But these CPU is perfect working for many years... any troubel is detected...
    Well, I've more confused now....
    P.S.: sorry my poor, very poor english...
  11. #386
    I am Xtreme
    Jan 2005
    Quote Originally Posted by So_BAD View Post
    NO CONTACT MARKS IN SOME CPU CONTACS...
    Doesn't really suprise me. I reckon Intel adds more VCC pads than the bare minimum just as a safety precaution.
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
  12. #387
    Apr 2006
    Sao Paulo | Brazil
    Ah, ok. Understand.
    As said:
    Pentium 4 531
    Pentium D 915
  13. #388
    Feb 2003
    Gothenburg, Sweden
    No, you're looking at the wrong marks. The highly visible marks are not caused by insertion in the socket, those are there from the factory. If you look closer at your own pictures, you can see faint dark spots in the middle of most of the pads on your CPU. Those are the marks that your socket has made.
    There is no way for the pins in the socket to cause the sharp marks that some of you seem to be looking for.
  14. #389
    Apr 2006
    Sao Paulo | Brazil
    Quote Originally Posted by Mikael View Post
    You is 100% right!
    I "paint" with permanet pen (pen to write in DVD's) some CPU electrical contacts and remount. When dismantled it, there is marks, exacly you told.
    Good job, Mikael !
    Well, return to zero point of my observations... and more frustade. Tomorrow I will UP the system, will see!
    By the way, I make contact with LOTES headquarter, talking about this socket 1156 issue. Me and some friends want to buy some complete LOTES LGA 1156 socket (PN: ACA-ZIF-082-K01), to replace Foxconn. Ms. Hellen Chen, tell me that they haven't a officer in Brazil. So they couldn't sale any parts here. See below.
    But they others sales representative officers, in Asia, Europe and USA. If we could buy a hundred of units, its solve the problem of many people, with the same afraid.
    Someone would contact they, to talking about this issue?
    De: Hellen Chen <sa11@lotes.com.cn>
    Para: Marcelo Gomes <sobad_br2@...>
    Enviadas: Segunda-feira, 2 de Novembro de 2009 4:59:12
    Assunto: RE: Socket 1156 Issue
    Hi, Marcelo,
    Thanks for your e-mail. We don't have any sales representative in Brazil
    For our business model, we will not direct business to end -user or retailers. Please contact the motherboard maker or shop for the replacement.
    Should you have any questions, please let us know.
    Thanks & Regards,
    Hellen Chen
    Marketing & Sales Dept.
    Lotes Guangzhou Co., Ltd.
    DID: 86-20-8468 6190
    Fax: 86-20-8468 2478
    E-mail: sa11@lotes.com.cn
    Website: www.lotes.cc
    Maybe togheter we could help us.
    Thanks!!
  15. #390
    Feb 2003
    Gothenburg, Sweden
    You is 100% right!
    Good job, Mikael !
    No problem.
    The problem is that the socket can't just be replaced. All of those 1156 pins in the socket are connected to the motherboard, probably through a ball grid array or similar. Removing the socket from the board would require heating the socket and board so that the solder points melt. You'd then need to restore the balls before putting on the new socket and once again heating it all up.
    This process is very delicate and cannot be done without expensive machinery. Simply put, it needs to be done at a PCB assembly house. The problem is that it would be expensive and I doubt anyone would even take on such a job. Besides, the likelyhood of failure (i.e. destroying the board in the process) is high.
    So, unfortunately, the best solution is to simply get a board with a LOTES socket already on there.
  16. #391
    Oct 2007
    2 weeks ago I got a P55-UD3R.
    Same exact issue.
    I ran it with an i5 750 at 4GHz (20x200), now it is no longer stable at that frequency. Can't run it at anything higher than 160x20... It also won't recognize all ram (sees 2GB out of 4).
    At least it still (kind of) works.
  17. #392
    I am Xtreme
    Sep 2006
    and your issue is directly related to the socket you think ? What did you test ?
  18. #393
    Aug 2007
    Germany/Bavaria
    First case I discovered at pcghx.de: http://extreme.pcgameshardware.de/ko...ml#post1258061
    Settings used: 4.3 GHz, 1.43 V Vcore, 1.25 V IMC @ Prime (water-cooled)
    According to the user he switched to 4.6 GHz and then BIOS/CPU-Z-detection went wrong. Then he looked at the bottom side of the CPU:
    Pic 1
    Pic 2
    Edit: Mainboard = Asus Maximus III Formula
    The Initial value finished
    PI calculation is done!
    Quote Originally Posted by Zeus View Post
    Software tweaks are not for sale.
  19. #394
    Oct 2007
    I can't say that that this is the issue with complete confidence.
    What I can say is that the board worked overclocked for two weeks no problem, Prime95 stable and was able to pass 10 iterations of intel burn test on a high setting. Then one random day I get BSODs out of nowhere, and the motherboard will no longer recognize all RAM. Thinking that my RAM has gone bad, I try a few other sticks, but I have the same issue. Flashing the BIOS to the newest beta one doesn't help.
    So I do a google search on why it wouldn't recognize all my memory. I find a few P55 threads saying that the pins on the socket might be bent. So I take off my heatsink and the CPU and what do I find... Warped pins. I can't take any pics since I don't have a camera, but some of the pics in this thread seem awfully close to what I saw.
  20. #395
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Lotes.
    I think this is far from over yet. Question is what is really causing this now.....1156 power design? Faulty cpus? or intels 1156 socket spec?
    http://www.ocforums.com/showthread.p...63#post6295863
    heatware chew*
    I've got no strings to hold me down.
    To make me fret, or make me frown.
    I had strings but now I'm free.
    There are no strings on me
  21. #396
    I am Xtreme
    Jan 2005
    Note: some companies used the Lotes holddown, but Foxconn socket.
  22. #397
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Thought EVGA p55 FTW was strictly Lotes?
    Here is my guranteed 100% foxcon.
    And here's the one on this particular board in above post.
    Note: The molds are completely different.
    heatware chew*
  23. #398
    Aug 2005
    Maryland
    Crap, I had a sneaking suspicion that this might come up. Now what? Ahhhhh
    >> i5 750 @ 3.6Ghz | CM212Plus + P12 | P55-UD3R [BIOS F2] | 4GB G.Skill CL8 | Zotac GTX 580
    .: 4 x 1TB WD | Corsair TX750 | Lian Li PC-A70A | X-Fi | Logitech Z-2300
  24. #399
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Quote Originally Posted by Mav451 View Post
    Ehh, I would not take that screenshot I posted as an end all........
    The location of the burn is rather "interesting" to say the least as it differ from all the others.
    heatware chew*
  25. #400
    Aug 2005
    Maryland
    Yeah I noticed the molding is different. Even still, people put tons of voltage in C2D (s775) and PhenomII's (AM2+/AM3) - I don't remember hearing a single burn story on the scale we are seeing from this new socket. The different location could be different...vulnerabilities? I dunno. I don't know the native language of that original link.
