XtremeSystems Forums
Go Back   XtremeSystems Forums > Official Manufacturer Information & Support > Foxconn - Quantum Force
Reply
Old 01-12-2009, 12:00 PM   #1
matttehman
Foxconn Destroyer Phenom II 940BE Build
As Soon as I get home I will begin the build! I'll try to get some pics up too. THe chip just came in and I'm excited to get started. I got #26 chip in the batch, so maybe it will oc well. But as of now I just have stock cooling & a big typhoon(for s939).
matttehman is offline   Reply With Quote
Old 01-12-2009, 08:42 PM   #2
matttehman
Aegis Panal seems to work fine for me?
I haven't checked bios revision yet, but i am waiting on a new one for max oc.
I am able to get it to 3700mhz. on stock cooling with stock volts(and 8 gigs of ram). I plan to watercool so it will be awhile befoe I can go crazy with it.
But so far my impressions of the board are allright. If i get to that Jack Sparrow then i will be a happy man! I will start a thread in AMD OC area when the time comes.
But if any1 has any helpful information on overclocking this board I would love to hear it.
ie: Where is that "musicismylife" dude and how did he hit 400 on air with this board?
Old 01-12-2009, 10:21 PM   #3
HDCHOPPER
wee haa welcome to the fox side !!
heres luck to your high oc build
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
HDCHOPPER is offline   Reply With Quote
Old 01-12-2009, 11:32 PM   #4
MusicIsMyLife
MusicIsMyLife's Avatar
Send a message via ICQ to MusicIsMyLife
Here I am....
I'm sorry but you're mistaken. We 'only' got 300 mhz out of Destroyer with aircooling (TRUE 120).
Maybe you thought of Fr3ak and his 417 mhz on Gigabyte GA-MA790GP-DS4H under cold air.
__________________
MusicIsMyLife is offline   Reply With Quote
Old 01-13-2009, 01:39 AM   #5
Fatalbert
Fatalbert's Avatar
what do you want to know ?
I know this motherboard and I think I can help but tell what you want
__________________
Originally Posted by dinos22 View Post
SuperPi is like caviar. It's an acquired taste.
Originally Posted by K404 View Post
"My Backup is bigger than Your Backup"
Live Extreme Overclocking Thread
Fatalbert is offline   Reply With Quote
Old 01-13-2009, 06:57 PM   #6
uwackme
hmmm
Does the Destroyer have a BIOS update available for the Phenom II ?
__________________
GA-MA790GP-D4SH, 940BE, 2x2G Gskill 1066
under test
Foxconn 590SLI, 5600+ @ 246Mhz x14
1.525Vcore, 1.35,1.35,1.35,1.525,1.5 chips
2x 2G GSkill 1066 5.0,5,5,15 @2.0V
P34 bios, 2x 150G VRaptor raid, 250G-IDE
8800GT 735/940/1685, LG-BluRay
uwackme is offline   Reply With Quote
Old 01-13-2009, 08:54 PM   #7
matttehman
Lol sorry guys I was excited.
@Music: I meant 4 ghz. Opps!
And Fatalbert: All your knowledge are belong to us!
But really I will ask questions as I encounter them.
Here is my setup:
CPU: Phenom II X4 940 (stepping info soon) running at 200x18= 3600mhz.@ stock volts
Cooler: stock
Motherboard: Foxconn Destroyer
Memory: GskiLL Pi Black(4 X 2gb) F2-6400CL4D-4GBPI-B
Graphics: Onboard( I have 2 7900gt's i might sli till I buy a new card)
Power: Cooler Master 750w
OS: Windows Vista Ultimate x86
Case: NZXT Guardian 921
I am migrating from a DFI LANPARTY UT nF4 SLI-DR Expert 939 ( and perviously an nforce1 ). Overclocking the dfi was pretty easy because even
though there were a ton of settings, there was an oc database on dfistreet that was huge. People would basically input every setting in the bios they
changed to acheive their O.C. i was able to take my opteron 144 from 1.8ghz. to 2.9ghz. 24/7 on air.
I know I will not see the same percentage increase here, but i would like to get as close as possible. So any little tweaks anyone finds with this board
would be greatly appreciated.
Old 01-14-2009, 08:25 AM   #8
Fatalbert
Fatalbert's Avatar
I saw only not public beta.
Here is my setup:
Cooler: stock
Case: NZXT Guardian 921messed up so the vapo doesn't stay on well.
If you ocing and you don't have rise vnb don't do it or your nb will on fire
enable igp in bios a if you can gave pwm air
__________________
Old 01-14-2009, 09:14 PM   #9
matttehman
What is rise vnb? My nb is cool to the touch..
Amd what is igp and why does it need air?
Old 01-14-2009, 09:18 PM   #10
matttehman
Ok lets get some settings shared fellows...
I was using this thread: http://forums.guru3d.com/showthread.php?t=267708 to help me overclock.
Is there a better OC Guide for destroyer's? It seems some options are missing for the NB.
__________________
FragBox:
CPU: Phenom II X4 940 Black edition CACVC AC 0849APAW running at 210x18= 3780mhz.@ 1.34 v
Memory: GskiLL Pi Black (4 X 2gb) F2-6400CL4D-4GBPI-B
Graphics: XFX GTX260 Black edition ,EVGA GTX260 SC @ 720/1500/1208
Case: Mountain Mods Ascension CYO
Current WC'ing Loop:
mcp355<mcr320<mcr320<Dtek Fuzion V2<gpu1<xspc restop<mcp355
Old 01-15-2009, 06:44 AM   #11
Fatalbert
Fatalbert's Avatar
it's not amd, it's nforce and he like to be hot.
even if firsts bios doesn't have some options, I hope saaya read it and engineers will add it.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
