Page 1 of 71 12341151 ... LastLast
Results 1 to 25 of 1751
Thread: The Phenom II List of Overclocks
    Feb 2008
    Northeast Ohio, Where the weather changes every 30 min...
    The Official Phenom II Overclocking Thread (Please Post Your OC's)
    Alright, so here's the thread that will have the overclocks of all Phenom II's by who has the highest overclock, and later on maybe by the 5 letter stepping at the beginning if we get lots of different ones like we did with rev F3 X2's.
    To be included in the ranking, you need to post the following information.
    CPU Model Used
    CPU Full Stepping
    CPU Frequency
    CPU Vcore
    NB Frequency
    HT Link Frequency
    Memory Frequency
    Memory Configuration (2x1gb, 2x2gb, etc)
    Memory Ganged/Unganged
    Mainboard Model
    Cooling Type
    Windows Version and x86 or x64
    You will also need screenshots of the following.
    Prime Stable 2 hours minimum for the list of stable clocks or OCCT 1 hour high priority, none for list of suicides.
    CPU-Z main screen and memory screen
    Not necessary but still appreciated
    CPU-Z Validation
    Get Overclocking Guys.
    Prime Stable:
    Suicide:
    Not much to say right now.
    Dec 2007
    Prime stable and 8 hours is useless
    Cpu:Phenom ΙΙ 965 c3 @ 4.1Ghz/2.8nb (air cooled)
    Mobo: Asus M3a79-T Deluxe
    Ram:A-data 2x2 800+ @ 1000
    Gpu:Asus Hd4850 512mb @ 700/1050(sycthe Musashi)
    Hdd:500gb Seagate 7200.11
    Psu:Corsair Hx620
    Cooling: TRue(dual fan)
    Case: Coolermaster Haf 932...
    Apr 2008
    With what the power set ups are like on alot of the mother boards prime for 8 hours mite kill the mother board . Some people have lost there mother
    board to long prime runs already so they may not wanted to do that just a thought .
    Phenom II 965 C3 @ 4 Mhz @1.4375v prime95 stable
    Asus CrossHair III Formula
    Cooler Master Aquagate Max cpu cooler
    Patriot AMD Black ED. ddr3-1333 OC 1600 8-8-8-20-28 (2x2GB)
    2600NB@1.350v 2200HT@1.206v
    2 Asus 5850s running in crossfire
    2 WD 320gig SATA-2 hard drives raid-0
    PC Power & Cooling 750w Silencer Crossfire ED.
    Asus DVD Burner
    Cooler Master HAF932 AMD Limited ED. case
    Acer 21.5" LCD 1920x1080P
    windows 7-64 bit
    Jan 2008
    milwaukee
    im with them guys, i have only run prime >1 hr maybe a handful of times and never >2 hrs,, too many horror stories lol
    LEO!!!!
    amd phenom II x6 1100T | gigabyte 990fxa-ud3 . .
    2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd
    sapphire ati 5850 | x-fi xtrememusic. . .
    samsung f4 2tb | samsung dvdrw . .
    corsair tx850w | windows 7 64-bit.
    ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . .
    lycosa-g9-z2300 | 26" 1920x1200 lcd .
    Nov 2007
    according to some, certoun heavy games results in crashes while prime seemed stable.
    for me, 3 hours of gaming and a 30minute prime run is a stability test.
    prime95 says torture test, and thats what it is, a torture. personaly, i will never run it 8 hours.
    also its unknown how long the phenom survives on high oc's.
    when i get my phenom, i will not put more on it then 1.45 volt. i will have to see how much mhz that will be.
    amd 940 @ 3.5ghz stock voltage or 3.7ghz 1,425v home made cpu block 3616 mhz and 2210mhz nb stable
    gigabyte ga-ma790fx-dq6
    sapphire hd4870 1gb @ 160-200 in idle , 750-950 load, with 2 rivatuner power profiles shortcuts.
    2x 2GB OCZ Blade 8500 ddr2 1066 @ 1.85 volt
    seagate barracuda 7200-11 1x500gb & 1x640gb (rip 1 500gb barracuda )
    seagate barracuda 7200-12 1TB , very nice hd, 5 degree colder then the 640gb
    windows xp 32
    lian li pc-a70b
    cooler master real power 850watt
    Feb 2008
    I guess doing prime for 2 hours would catch most errors, maybe people could switch it to a custom test that switches fft length after every 10 minutes instead of 15 so they still get all the tests in the 2 hours. What do you guys think about that?
    Jun 2003
    I knew I shoulda snapped a SS when I killed prime after 10hrs
    gonna try for higher on a later date anyways...
    My Heat
    gd-70\955\2x1gbhz1600
    ext-58\920\3x2gb998691
    Expert\170\2x1gbhz
    Xtreme X.I.P.
    Oct 2006
    2h prime95 is plenty IMO. 4 times longer priming doesn't mean 4 times the stability Besides, it's to everyone's interest to have as many OC's as possible, and I'm pretty sure alot of people are WAY too impatient for 8 hours.
    --->TeamPURE<---
    Jun 2003
    Quote Originally Posted by knopflerbruce View Post
    some times prime will not error until later in the run 2 hrs IMHO is no where near a stable rig. Unless you have it in a oven at 200 degrees
    My Heat
    Expert\170\2x1gbhz
    Feb 2008
    If people want to do longer than 2 hours, that's their choice. We can just make the minimum stability test to be 2 hours of it. And more overclocks is always better.
    Dec 2007
    With my 9950 when i primed for an hour , i said that's it!, no more torture we are good. And i was good, never ever crashed with that setting no matter what i did. Although When i was stable for 30 minutes neither did that o.c ever crashed, games,encoding nothing.I just think prime is too much....
    Psu:Corsair Hx620
    Jan 2008
    Lubbock, Texas
    Quote Originally Posted by Oldguy932 View Post
    yea thats fine in the last thread there wasn't even a requirement but for every result someone submitted it would say how long they primed or say nothing at all if they didn't do it. maybe we can do something similar?
    Apr 2008
    My self i use a 1-2 hour prime run to test my over clocks with and that has work good for me also . Just did not want to see guys get stuck in a long prime run and have them maybe break rigs .
    Asus DVD Burner
    windows 7-64 bit
    Dec 2007
    Quote Originally Posted by roofsniper View Post
    +1 for that.
    + stable oc list and suiceide max screen list
    Psu:Corsair Hx620
    Feb 2008
    I'd rather not do suicide shots because that doesn't really show the potential of the chips in my opinion. I mean really, how hard is it to run prime? If you guys want I'll do lists with and without stability, but I don't see the use of using suicide shots when this is supposed to be a resource for people to look for what steppings are the best assuming we get a lot of different steppings.
    Also, we've had how many posts and not a single overclock yet for me to document.
    Edit: Leoy beat me to saying do two separate lists.
    Dec 2002
    no prime for me, theres no way I would ever need my rig to run 100% for hours at a time. I overclock for fun, benching and for my games and thats it. Im not going to torture for no reason. highest oc and settings and 24/7 oc and settings ahould be sufficient. An easier test should be maybe 3dm06/ vantage or something for proof the system runs on a decent load?
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
    Jan 2008
    Lubbock, Texas
    its not like if they aren't running prime for 2 hours its a suicide. i myself have only ran prime for 2 hours once because i was watching a movie. typically when i have problems with things not being stable prime will pick it up within 10 minutes. its fine if people run prime for 2 hours just some like me don't feel like doing that all the time.
  18. #18
    Xtreme Mentor
    Dec 2007
    State of Confusion, USA
    Just a suggestion.... Instead of 2 hours Prime why not use a good 10 pass Linpack (IntelBurnTest) run to show stability.
    It pushes harder and has shown (to me atleast) to be just as reliable but only takes about 20 minutes to run (less chance of damaging the PWM section of your board).
    http://www.xtremesystems.org/forums/...87&postcount=1
    AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
    Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
    First Computer: Commodore Vic 20 (circa 1981).
  19. #19
    Dec 2007
    I
    The use of this thread should be about best stability, in search of best stepping, cause the stepping is indeed useless in max suicide shots.
    But a small list with validation only should be nice.
    Also prime isn't the program everyone using so we should find somethimg simplier perhaps.
    And prime can and will give u errors in within 30 -1 hour if not stable.
    Psu:Corsair Hx620
  20. #20
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Quote Originally Posted by crazydiamond View Post
    You guys are fresh on the Boat aint ya? We at one point would not consider a Overclock Valid unless a Full 8HR Prime 95 Run was done immediately Followed by 3DMARK 05 -03 then you could post your overclock achievement
    OK......Then........1HR CPU High Priority of OCCT
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
  21. #21
    Nov 2007
    you cannot oc a chip and not test it with 100% load.
    so i agree with prime, it must be used to proof stability.
    when i test for oc walls, i start prime and slowly turn up the htt bus untill it starts to error. then i play with voltages and other things.
    windows xp 32
    lian li pc-a70b
  22. #22
    Feb 2008
    I'm fine as long as we can agree on something. I originally posted the 8 hours prime because that's what it was like last year and the year before(meaning 07 and 06). I've never managed to run the intel burn test on my 9600, but it doesn't crash even when I have it run wcg for days on end. I'm also fine with OCCT, last time I ran that program was when it was only for single cores.
  23. #23
    Nov 2007
    as maintainer of the list you can demand more proof of stability and only add to the list like you see fit.
    windows xp 32
    lian li pc-a70b
  24. #24
    Jan 2008
    Lubbock, Texas
    well the reason why i say we shouldn't have a prime requirement is because many people are too lazy. if you looked at the old thread in all of the info listed in the spreadsheet one column would be for how long it was primed. it was blank if no one primed it and if they did it would be listed. if people see that it is completely blank then they would know that theres a possibility that its not stable. i think 2 hours is fine tho like i said prime usually picks up errors for me pretty fast if its not stable.
  25. #25
    Banned
    Oct 2006
    Haslett, MI
    It's simple guys: If you want to list stable overclocks, then change title to read: The Phenom II Stable Overclocking Thread or something similar. If it's just overclocking then everything goes.
