I have been following XS water-cooling galleries and work-logs for some time now. I just converted my test bench to water-cooling and I now want to track my progress with a work-log covering my first adventure into "modding" and building a water-cooling rig. But before I begin ... a bit about my self and what I do. I live in Tok, Alaska and I manage a small computer repair business known as The Computer Cabin. I have been involved with computers for over 24 years so I "know" a few things about what makes them tick and what they are supposed to do.
I currently have an ASUS Rampage Formula on the test bench with a QX9770 in it that is water-cooled with a D-Tek FuZion v2 waterblock. I have a XSPC 500ml passive reservoir with a MPC-655 pump/EK block top and a PA120.3 radiator w/shroud and three Noctua NF-12P fans. Here are a few pics with the window/radiator set-up that I lovingly call the, "Arctic Breeze Way."
The window can be adjusted for cool air to be "pulled" through the radiator. I have tested this and with two thermometers connected to the outlet side of the loop (coming from processor and going into rad) and the intake side (coming from the reservoir side going into processor) ... plus a thermometer for the outside temps ... I can say that there is at least a 1~2 degree difference. The XSPC reservoir is aluminum and it does cool the liquid quite nice. I have a second one being delivered as well as other fittings as I plan on incorporating a second loop for my two HD4870 X2s. Only one is shown on the test bench for the moment.
The plan is to build an i7 rig with an undetermined X58 motherboard (DFI LP X58-T3eHS is being considered heavily, but waiting for an extensive review from a few notable websites) and already purchased i965EE and 6GB Corsair Dominator DDR3 1600 memory. All of the internal goodies will go into a Temjin TJ-09 black case that will have some "minor" mods done to it. As always, with what I have in mind and what you guys suggest are open for discussion and I do literally hope for good advice, as this is my first time doing any type of water-cooling and modifications. Here is a pic with some of the stuff I already have ...
Here is the Temjin TJ-09 before I gutted it completely. I have some ideas about what I plan on doing. I will get to that a little later ...
I plan on using black 3/4" Tygon tubing (have) along with BitsPower compression fittings (have). However, I will also use Koolance quick-disconnect fittings at the back side of the case so that I can easily move the case from the Arctic Breeze Way when needed. I'll try to do a short mock-up of that later. I plan on using a dual radiator INSIDE the case strictly for water-cooling the NB, should I elect to do so. I already have an internal XSPC single bay pump/reservoir and a Swifttech radiator that will fit in the Silverstone case. An additional EK 400ml reservoir is waiting in the wings if needed. I have loads of Fesser fittings and BitsPower fittings so hooking things up won't be a problem. I just have to decide on the motherboard so I can measure where I need to modify the mobo tray for wiring and so on.
I have a Silverstone Decathlon 1000W PSU and I have never attempted any type of sleeving modification and would love to know more about the art. Any links would be greatly appreciated, though I have done some simple molex repair and such, my expertise is limited severely. I am just a noob after all.
I have a lot of work to do, and I am eagerly awaiting on any comments, suggestions, and advice. I will post more as I go along. Thanks in advance for your patience.
AK
