Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Thread: Last one, My Q6600 CPU Waterblock Roundup Results
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    I still had this last bit of data to share before retiring from testing. I didn't get to all of them, but most. In spirit of minimizing the BS, here is primarily just the data with a few random thoughts at the end. Special thanks to Sidewinder, Swiftech, Danger Den, D-Tek, Enzotech, OCZ, XSPC, TFC, and NCIX, and Rick Cain/Niksub1 for providing the samples.
    Thermal Test Specifications (for us testing geeks)
    For thermal testing I decided to try and follow a 5 mount method of logging temperatures. Here are some of the specifics in my testing method:
    • Real World Full System Testing - Over time I developed a radiator testing bench that I've decided to incorporate into my CPU block testing setup. This gives me a full 8 air inlet sensors, 4 air outlet sensors, and two water sensors to much more precisely monitor everything. My testing occurs as close to the real world as possible, I just have a crap load of sensors on everything. I am testing on a processor, with a loading program, in a real world computer case, with a fixed pump, and a regular radiator setup. All of this helps include the little odd things that actually occur in a regular system.
    • Intel Core 2 Quad Q6600 Kentsfield Processor - Overclocked to 3600 MHz, 65nm, Vcore = 1.472 under load. Motherboard is a DFI Lanparty X48 LT with 4GB of Corsair Dominator memory with fan module. The northbridge and southbridge chips are both watercooled. Video card is an EVGA 8800GTX, also watercooled. Case is a Thermaltake Armor, position is horizontal for easy block mounting case cover left off.
    • 5 separate TIM applications and mounts averaged - This is not common, but extremely important. It's not uncommon at all to see mounting variations as high as 2 degrees or more, so with only one mount, that error is 2 degrees. When you mount 5 times and average those results, your standard deviation is significantly lowered and the overall testing confidence improved. In addition multiple mounts serve as a means to validate data, because each test is carried out again and again, chances are if some variable is affecting results, it will show.
    • Logging temperatures - After several iterations of a new testing method I finally landed on logging of temperatures for 1 hour. I then can simply start up the loading routine, and trigger on my two logging programs and walk away for an hour. I then come back and remove the first 10minutes for warmup time. The remaining 50minutes is then left to average out temperatures which are recorded every second over 18 active sensors plus 4 core temperatures. Logging is essential for higher resolution measurements. Our DTS core sensors are only resolved to 1C, however after logging that resolution out for 50 minutes of testing, that can be reduced significantly. In addition my ambient temperatures are held constant by an A/C system thermostat that actually makes the temperature swig up and down in a sawtooth like fashion over a 2C limit. Logging this sawtooth occurrence over a long period of time also levels out the ambient to a nicely resolved level of accuracy.
    • Temperature Probes Deployed - I kept my sensors fairly basic, but I did run a few extra's just for interesting information. This includes a sensor for:
    • 2 ea Water Out sensors (After radiator and before CPU block) Dallas DS18B20 Digital one-wire sensors, and CrystalFontz CFA-633
    • 8 ea Air In Bottom (Bottom inlet side of radiator) Dallas DS18B20 Digital one-wire sensors, and CrystalFontz CFA-633
    • 4 ea Air Out Top (Top out side of radiator) Dallas DS18B20 Digital one-wire sensors, and CrystalFontz CFA-633
    • 4 ea Q6600 DTS sensor these were logged using Core Temp Beta Version 0.94. I chose this particular version because it stacks logged data cores in separate column which makes integrating into my crystalfontz data much easier.
    • Crystal Fontz logging is accomplished through the use of their Cyrstalfonts 633 WinTest b1.9. Only special settings are turning off all packet debugger check boxes to avoid paging the processor.
    • The Dallas DS18B20 Digital one-wire sensors that were used as noted above have a specified absolute accuracy of .5C with a .2C accuracy between 20 -30C temperature range. They also have resolution down to .0625C which is very good, and because they are digital they are not affected by the wiring or length of wire like thermocouples are.
    • The CrystalFontz CFA-633 is an LCD with up to 32 channels of monitoring and logging capability. It logs temperatures of each channel on a one second interval, so over a 30 minute test, I'll have about 1,800 entries noting time and temperature of each channel. These are then averaged for a fairly accurate number.
    • Pump - Laing DDC3.2 with XSPC Reservoir top. I think this pump represents the pumping power available to many users and gives a fair amount of strong pumping power. This top rated near the top in my pump top testing and is very powerful.
    • Radiator - The Feser Company (TFC) 480 ER radiator with Yate loon D12SL12 medium speed fans at 12V with TFC shrouds in pull condition. This is an extremely powerful radiator and was purposely chosen because the smaller water/ambient deltas reach equilibrium fast and pressure drop for this radiator is minimal. This provided me very short warmup periods and ensured maximum pumping power for the CPU blocks being tested.
    • TIM Material - While I really like the TIM consultants TC Grease 0098, I found the thicker consistency wasn't helping with mounting consistency and required user effort to seat the block down. For that reason I chose Artic Cooling MX-2, it's been very popular in the forums and preliminary testing showed to perform well, it's noted as non-curing, and more importantly is a thickness/consistency that more accurately represents most thermal compounds and easily applied and removed. I felt this was important to maintaining a higher level of repeatability. There was no cure time allowed for the compound (even though it's noted as a non curing compound). Testing was started immediately following block installation. TIM installation method is the thin line method.
    • Hardware - These results only tested the "As Shipped" method that use the hardware included and provides users some evaluation and performance of what you get straight from the box unless noted with a backplate. During supreme testing round 2 I found that adding a backplate and using the same mounting pressure didn't result in any notable difference. So in effort of protecting my valuable motherboard, I used a Scythe backplate during those tests and they are indicated by a "Scythe" backplate notation on the results.
    • Prime 95 Load - I used Prime 97, torture test, Custom, Min FTT 8K, Max FTT 8K, Run FFTs in place checked ON. This is an easy to use and constently loading program. It provided the most consistent loading I could find for quad cores.
    • Lapped IHS - My Q6600 has been lapped flat down to 1200 grit to ensure a true and flat surface. The stock intel IHS can be very irregular, some are convex, some are concave, some are wavy, and some are fairly flat. Lapping a processor voids it's warranty, but it ensures a nice flat surface for optimal heat transfer. My particular processor has been lapped. A complete stock IHS may benefit more from a bowed block than my samples because it is flat.
    • Fixed Ambient Temperature - My recent roundup of block testing brought forth that regardless of measuring water temperature you will in fact still incur testing error of the processor core temperatures if you allow ambient temperatures to fluctuate. I found on the order of .2 t .3C error for every degree in ambient difference, although it was too variable to pin down and appropriately correct for. In the end I decided on buying a window A/C unit that holds all testing to the same temperature. Ambient do go up and down as the thermostat kicks on and off, but the overall average temperature over a long logged test has been holding to less than .5C which is very good. I am running a Hair 8,000 BTU thermostatically controlled A/C unit in "Cool fan on at all times" to keep temperatures at 22C plus or minus about .5C on average over the length of the test.
    Thermal Results
    As Tested Resulting Flow Rate
    Pressure Drop - Restriction
    Mounting Mechanism
    Apogee GT - Bottoming screws ensures accurate/even pressure, Back-plate
    Apogee GTZ - Bottoming screws ensures accurate/even pressure, Back-plate
    Danger Den TDX - Standard springs/open thumb-nut
    Danger Den MC-TDX - Standard springs/open thumb-nut
    D-Tek Fuzion V1 - Standard springs/open thumb-nut, Back-plate
    D-Tek Fuzion V2 - Bottoming screws ensures accurate/even pressure, Backplate
    EK Supreme - Standard springs/open thumb-nut
    Enzotech Saphire RevA - Bottoming nut ensures accurate/even pressure, Backplate
    OCZ Hydroflow - Bottoming nut ensures accurate/even pressure, Back-plate
    XSPC Delta V3 - Standard springs/open thumb-nut
    Material
    Apogee GT - Machined Copper Base, Cast Delrin Top
    Apogee GTZ - Machined Copper Base, Machined Delrin Top
    Danger Den TDX - Cast Copper Base, Laser Cut Acrylic or Brass Top
    Danger Den MC-TDX - Cast Copper Base, Laser Cut Acrylic or Brass Top
    D-Tek Fuzion V1 - Cast Copper Base, Cast Delrin Top
    D-Tek Fuzion V2 - Cast Copper Base, Cast Delrin Top
    EK Supreme - Machined Copper Base, Machined Delrin or Acrylic Top
    Enzotech Saphire RevA - Forged Copper Base, Forged Copper Top, Plastic Cover
    OCZ Hydroflow - Machined Copper Base, Nylon Top
    XSPC Delta V3 - Machined Copper Base, Machined Delrin Top
    RANDOM THOUGHTS
    In the end for me, they all passed. They all cooled my Q6600 more than enough to run the overclock I was running. During the winter when not testing and running a wood stove, I can see up to 15C fluctuations in house ambient temperatures so 4C is really tight in that context. In addition with the mounting variations and limited DTS sensor resolution, the thermal results are still only good to roughly 1-2C so I can't help but feel many of the results are simply too close to conclude much of anything but that they did cool the processor down well enough. I was surprised how close the results are thermally, obviously we are coming to a barrier in thermal efficiency. More importantly these results only apply to this one processor, it would be different for dual core, or larger cores. Generally I think blocks that have very small center nozzles would do better from smaller processors and those with long spread-out type nozzles or distributed flow paths would do better with larger cores. Most people will likely see more gain by doubling up on their radiator capacity than changing out of CPU blocks. If the average radiator water/ambient delta is 10C, doubling the rads would be worth 5C which is greater than the difference between any block here. The differences are just pretty small...and frankly hard to even measure.
    Also note the mounting mechanism differences. The old spring/open nut styles are not going to be as easy to use and ensure even mounting pressure as those that have some sort of bottoming nut or other design item that prevents the user from tightening one side or corner more than the others. Furthermore, some come with back-plates while others do not, you better plan on buying one for those that do not, it's essential in protecting your motherboard and a hidden cost.
    Finally bowing and stepping do help with the last few bits of efficiency, although they also have some negatives. They work by increasing mounting pressure per unit area for the critical surface directly above the die. However they work against mounting consistency and are more difficult to mount because of this. Finally some may or may not be optimized or designed to cover larger or smaller cores. I like a small amount of bowing myself, it seems to work like camber in a bridge if nothing else and counter the flex of the block in high pressure applications.
    Just one set of tests, under one set of conditions, using a lapped Q6600 processor. I make mistakes like anyone, your results may differ especially if it's any other type of processor.
    Cheers!
    Martin
    May 2008
    Ontario, Canada
    Omg. Thank You!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Aug 2006
    Oklahoma
    Keep this up on the forums, Please.
    _______________
    Q66@3.8ghz
    Rampage/Maximus SE hybrid W/C. 4 gigs OCZ reapers.
    4890,s CF Dual loop rocketfish case.
    ^^^^^All shaken, (from the earthquake) not stirred^^^^^
    Quote Originally Posted by Vapor View Post
    There's a lot less voodoo in watercooling than is assumed
    The only thing future proof in electronics, is the electricity itself.
    Any one who relies on only one source of information is a fool.
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    okey to everyone that laughed at me when i told them straight up the Supreme was the best.
    I get my final laugh.
    Thank you martin for all your work, and thank you for proving once again, i was correct.
    okey leaving ego after this post promise!!!
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Xtreme Mentor
    Jun 2007
    Chicago
    I'm glad I went with the supreme. It seems strange the backplate got somewhat worse results with it. I wonder if the results would of been any different between the gtz and the supreme, if the cpu was not lapped.
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Banned
    Oct 2008
    Dartmouth NS Canada
    Quote Originally Posted by NaeKuh View Post
    Maybe to be the best they should work on their flow abit eh?
    May 2008
    Ontario, Canada
    WHen was supreme's crown ever contest? Since I've known about XS i've known it was (best single block chip with non-german flow)
    Chasing After Diety
    Jan 2007
    Quote Originally Posted by 2low4u View Post
    uhhh...
    then it wouldnt be an accelerator class block... and wouldnt be the best.... And you kill its flow even more with tighter and more focused accelerators, it does EVEN BETTER.
    So therefore... what are you getting at?
    Quote Originally Posted by Bojamijams View Post
    dates back a long time ago during the fusion frenzy. Fusion best this, fusion best that.... Then i showed XS the supreme. Yes it was ME. More tweeking later, i told everyone, fusion is only best when you need low restriction.
    <got laughed at more> no im being serious.... then i just gave up testing to public.
    Never go full retard
    Feb 2008
    Vegas
    Absolutely wonderful testing and data presentation!!!
    Thank you for all of the long hours and hard work that went into this round of testing, we all appreciate it.
    BTW, thanks for raising the bar even higher.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by Eddie3dfx View Post
    Two different Supreme blocks, two different GTZ blocks. There's also plenty of testing error to make it pretty much hard to say anything conclusive.
    Anyhow, if I could emphasize one thing it would be don't trust the results anymore than about 2 degrees. The ups and downs in the mounts is a good indication just how much error there is.
    75 mounts later was a painful lesson in reality that testing CPU blocks is really difficult to produce anything very conclusive using the processor DTS sensor.
    And yes, my processor was lapped, a differently shaped IHS very well could produce a different result. At the same token no two IHS are shaped the same so you could again get two different results from two stock IHS processor.
    It sucks, but it is what it is....not very precise.
    It was a good learning experience though, hope it helps some....
    Thanks!
    Martin
    Xtreme Mentor
    Jun 2007
    Chicago
    Quote Originally Posted by Martinm210 View Post
    Thanks!
    Martin
    Within 1c is precise enough
    In a testing environment where there are so many different variables, you've done the best job that one can do.
    I think when I see your data and I see other people's data, I can then get a better idea of what is the best.
    excellent work.
    Btw, my gigabyte p35 held my x3210 up at 3500mhz at 1.53v for 6 months before it blew. It's probably the best cpu to judge the performance of these blocks, since they require so much voltage.
    Apr 2008
    Ottawa, Canada
    Thank you so much for this. Very much appreciated X1000. Hopefully this will be a sticky somewhere!
    Sep 2008
    Down the rabbit hole
    What's the difference between Apogee GTZ and Apogee GTZ #2?
    Ba da dum dum dum.
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    I think when you really look at the results and take the Extreme "i'd sell my XXXXX foir a extra degree" that most blocks are pretty equal, there are a lot in the middle of the pack, some are more or less restrictive but that is a function of many or single blocks in your loop, that is a credit to the block makers,'
    So if you play your blocks to their strengths then they will shine for you and if not, you might loose 2 degreez,.
    thanks for the post Martin! another great eye opener.
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
    Aug 2006
    Oklahoma
    Thanks!
    Martin
    Basically the thing to tell new watercoolers is that most of the
    blocks you test are pretty damn close overall.
    There are more things to worry about.
    Like.
    Mounting.
    TIM and how it is applied.
    Ambients.
    Pump.
    Radiator size.
    How many components are in a said loop.
    You have done the best you can do which is better than any other
    i have ever seen.
    You have done your best to make the test as close to identical
    as anyone can.
    Great job over all.
    _______________
    Q66@3.8ghz
    Sep 2007
    Sydney - Australia
    Thankyou so much for all your hard work Martin - what a way to finish up. I love how you make it so easy for everyone to read including those of us who don't know too much about the technical side of things.
    I really appreciate everything that you have done for the community and I wish you all the best with your future endeavours
    Feb 2008
    Vegas
    I have several of the blocks...will be interesting to see how close our results are when I wrap up my testing.
  18. #18
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Don't forget that for a while the fuzion was on top because the Supreme didn't exist
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
  19. #19
    Oct 2008
    Now that's a grand finale! Bravo!
  20. #20
    Mar 2007
    Sydney, Australia
    Way to go out with a bang Martin
    Thanks for all the blood sweat and tears you've put into testing wc for us I think it goes without saying... We have an enormous amount of appreciation for not only your work but also yourself. You'll be sorely missed around these parts
  21. #21
    Jun 2008
    Los Angeles, CA
    Martin, you're the man, awesome write-up
    Quote Originally Posted by sirheck View Post
    Like.
    Mounting.
    Ambients.
    Pump.
    Radiator size.
    i have ever seen.
    as anyone can.
    Great job over all.
    Very well said sirheck, pretty much sums it up.
  22. #22
    Mar 2006
    Los Angeles CA
    You sir are a water cooling god.
    Can we get a custom rank for him?
    Your dedication to this entire community will be forever remembered.
    Hopefully you'll find some time to swing by on occasion and say hi.
    Thanks again Martin!
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
  23. #23
    Apr 2008
    very nice thanks for this
    I7 920 W/ Enzotech Sapphire
    Asus P6T
    4870x2 W/ XSPC Fullcover
    6gb Gskill 1600
  24. #24
    Unoriginal Macho Energy
    Dec 2002
    Martin, nice work as always... sorry about the 5 mounts They suck don't they? You can actually thank Bill Adams for that, I think he used to do 10 mounts! Bottom like is with IHS over heat source, we are sort of at a brick wall.... anyway great job!
    Meh, in all my testing I could get the fuzion to outperform ANYTHING... that block is so tunable it is sick. To this day, lowest recorded temp with the fuzion v1, custom bow via o-ring and the 4.5mm nozzle. Nothing better IMO.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
  25. #25
    Xtreme Mentor
    Sep 2007
    Dallas
    WOW, RRR was right
    EK Supreme.... Reigns Supreme.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
